Old 02-08-2016, 11:58 PM
MikeS MikeS is offline
Came across this year-old thread and am reminded I ought to mention that Ellison Fluid Systems has been bought by an E-AB builder and entrepreneur based at Chino - Steve Glover, who I've known for many years. His company, NvAero:
http://www.nvaero.com/blog/ellison-fluid-systems/
I bought my plane in 2006 with the engine/carb that it's still got. In almost ten years I've never once had to adjust, clean or touch for any reason my top-mounted Ellison. I took my heads off about four years ago to replace valves & springs and just clean things up. All piston tops and chambers were identical in color, as if the engine had fuel injection with perfectly balanced injectors. The spray bar on the Ellison creates a fine, even mist that, combined with tuned inlet manifold tubes, provide each cylinder with an equal amount of perfectly-mixed fuel vapor.
It has never once collected ice, despite my propensity for flying in conditions that are conducive to it.
I've had it explained to me but still can't remember how it does it, but the Ellison somehow automatically leans the mixture as you climb. It has a mixture control but I've discovered using it, especially at altitude, usually does more harm than good. The darn carb leans itself as you climb.
It's a Smart Carb
Old 02-09-2016, 09:05 AM
JonJay's Avatar
JonJay JonJay is offline
Interesting news. Mine for the Bucker was just serviced at the original Ellison shop last fall. First flight was two weeks ago. Ran beautifully. I am a big fan of this product and glad to see they are going to be back in production.
As far as the self leaning, I am totally unaware of that. I flew mine for 150 hours or so and always leaned the old fashioned way; pull mixture to loss of rpm or slight stumble, enrichen until smooth running. Always worked as expected.
RV6 - Builder/Flying
Bucker Jungmann
RV1 - Proud Pilot.
