  #11
Old 01-28-2016, 05:52 PM
cjensen's Avatar
cjensen cjensen is offline
Originally Posted by alex48 View Post
<snip>Talk to Chad and he seems to be familiar with the flap problem, if the board was a specific serial number then they would swap the board. <snip>
This is incorrect...we have seen a rare issue that has to do with a particular flap controller. It has nothing to do with specific serial numbers.
Warranty on any VPX is from the date of purchase, whether from the old Vertical Power company, or from Ballard Technology. Nothing new or out of the ordinary here.
However, I am very interested in Alex's questions at the end of his post, specifically hours flown.
Chad Jensen
Astronics AES, Vertical Power
RV-7, 5 yr build, flew it 68 hours, sold it, miss it.
Old 02-07-2016, 10:34 AM
alex48 alex48 is offline
Default The right thing
The hours flown in aircraft as of today 5.2. I did have a fellow builder stop by and he has flown over 200 hours using VPX and has no problems. Mine was definitely defective from the beginning but I could not recognize the problem. I kept thinking that it was the potentiometer (sends flap position info back to VPX) causing the problem so I kept adjusting the position on the VPX, eventually damaging the unit.
At the end the company came about and issued credit for $350. For future builders you can get the wiring kit first, run all your wires and then buy the VPX. This way it would be under warranty on your first flight.
Received the unit today can't wait to install and fly the plane.
As far as support from the company, I can't say more about Chad, he is a super guy and offers outstanding support.
Old 02-08-2016, 09:46 AM
cjensen's Avatar
Thank you Alex! I'm really happy with the outcome, and I appreciate the feedback!
Chad Jensen
Old 02-08-2016, 09:56 AM
Guilhermepilot's Avatar
Guilhermepilot Guilhermepilot is offline
I would never give up my CB's to put this stuff, it is expensive, unreliable! We are flying nice and simple machines, keep it simple.
Guilherme Plassmann (Brazil)
RV7A (Mr Flame) slow kit S/N 74285 Finished 04/14/15😀😀😀😀flying
G3X
Superior IO360
Sterba prop
TSFlightlines hoses
LR30,PRM1,C560,C510S,HS125,B350 FAA/ANAC Pilot
Donation made 2016
Old 02-08-2016, 10:06 AM
Auburntsts's Avatar
To each his own. However, to say it's unreliable is a bit of a stretch IMO. Also a VP200 is way more than just electronic CBs. Switching it out for analog CBs is way more complicated than you make it out to be.
PP ASEL-IA
RV-10 N728TT - Flying!
WAR EAGLE!
Old 02-08-2016, 02:08 PM
ccrawford ccrawford is offline
I wonder if Ballard would be interested in releasing the software source code for the VP units under a GPL license. It sure would be nice for the community to be able to support itself on the software side.
They could even release the schematics for the boards under an open source license and let us get our own boards made (or even modified!) so we can keep the systems flying.
// corey crawford
// rv-7a (sold)
// denver, co @ KBJC
Old 02-08-2016, 04:41 PM
rleffler's Avatar
rleffler rleffler is offline
That's assuming that the code for the vp-200 is owned by Ballard. I suspect it may not be.
Bob Leffler
N410BL - RV10 Flying
http://mykitlog.com/rleffler
Old 02-08-2016, 07:45 PM
SMO's Avatar
SMO SMO is offline
I have discussed this with Chad, initial answer was "maybe" under the terms of an NDA, however we have not gotten a "yes" yet.
Astronics Ballard Technology is the organization that would need to release the Intellectual Property.
Mark Olson
1987 RV-4 Sold
2003 Super Decathlon - Sold
F1 EVO Rocket, first flight May 31/14
First in line for the Sonex JSX-2T kit
Old 02-10-2016, 09:36 AM
cjensen's Avatar
This is still an open discussion internally...I still have your email in my inbox Mark. Priority hasn't been with this at Ballard, but it isn't forgotten.
Chad Jensen
