Old 02-03-2016, 09:46 AM
dweyant dweyant is offline
Default Ground loop/hum?
I am using LED strobe lights, and I really like them.
However, I will sometimes get a hum in them when they are on. I have ignored it for a while since the plane was new and I was working out other issues. But I've gotten to the point that I'd like to get it fixed.
Here is the "interesting" part. I only get the hum some of the time, and only on the pilot side, not on the copilot side (RV-9A).
Any suggestions on how to track this down?
-Dan
Dan Weyant
RV-9A N96KD
Done and Flying 4/30/2015
Old 02-03-2016, 10:29 AM
SmilingJack's Avatar
Are your wires shielded?
John Mastro
RV-8
Old 02-03-2016, 02:20 PM
deene deene is offline
Will need details on your schematic and wiring...
Deene Ogden.
N399AD RV-12...flying
N299AD RV8 QB, IO-390X, BA prop...SOLD
N199AD One Design...SOLD
N99AD BD4, flew for 22 years...SOLD
EAA Tech Counselor/Flight Advisor
CFII, MEI, CFIG
Old 02-03-2016, 04:12 PM
Yes, shielded and grounded per the plans.
-Dan
Dan Weyant
RV-9A N96KD
Old 02-03-2016, 06:12 PM
-Dan
What kind?
I had that issue with an early version of AeroLED's.
Dean told me how to add a resistor and a capacitor which I did and it went away.
I also had an unshielded wire which I replaced and that too helped.
John Mastro
RV-8
Old 02-04-2016, 06:47 AM
GalinHdz's Avatar
GalinHdz GalinHdz is offline
Can you post this so others can do the same if they run into a similar issue?
Galin
CP-ASEL-AMEL-IR
FCC Radiotelephone (PG) with Radar Endorsement
2020 Donation made
www.PuertoRicoFlyer.com
