01-30-2016, 08:16 PM
Surprise during taxi testing
I'm only days away from first flight (waiting on current strong west winds to drop for my north/south runway) so I'm doing some taxi testing. Life is good - so much so that a good friend of mine wanted to ride with me and kick the rudders a bit for grins himself. In doing so we discovered an issue - the right hand copilot brake pedal was sticking and would not return. After he kicked the pedals around a bit, the right brake was dragging and quickly got hot. This is not something I would have caught until who knows when...
This is why we test - because we don't know the things we don't know.
01-30-2016, 08:38 PM
Good catch Greg. Remember there are known knowns. These are things we know that we know. There are known unknowns. That is to say, there are things that we know we don't know. But there are also unknown unknowns. There are things we don't know we don't know. Keep testing.
01-30-2016, 09:28 PM
I think I know what you mean.
01-31-2016, 05:54 AM
I'm impressed
The Vladster is writing in his third language, here. That he follows his own discourse here is accomplishment enough to have my respect.
-Stormy
01-31-2016, 06:44 AM
Greg
There are some mods you can do to help keep the brakes from sticking.
I did the first two listed on the first post of this thread.
http://www.vansairforce.com/communit...ad.php?t=46755
Brakes work smoothly & pedals return where they should.
Sam
Sam Evans
RV7-A O-360 C/S
VAF#812
01-31-2016, 07:26 AM
Been there done that
I immediately had to add the return springs using the parts in Daryl's post.
Taxiing with sticky brakes was no fun at all.
I think I confirmed the right side was just as bad, and ordered parts for both sides.
Filling the brake system from the bottom up is a lot easier when the masters are fully disengaged!
01-31-2016, 07:31 AM
Originally Posted by chipf
Same here but only for the passenger side. Quick easy fix and no problems since.
Larry New
RV-7A - Built, flying 900+ hrs
RV-10 - Built, flying 2.9 hrs
??? - RV-12, Subsonex
48 States in 7 Days!
VAF Paid - Annual Autodraft
01-31-2016, 08:44 AM
I was in a one mile long departure line at Oshkosh. There I am, third from departure and my left brakes sticks. I am sure the guy behind me thought I was nuts. I did a 360 and luckily got it unstuck. I need to install the spring kit. Oh how I dread the dive under the panel.
Alton DeWeese
N526RV RV7A Tip Up, IO360 180 W/Hartzel BA prop.
Flying ~950 hours since Aug 2010
N4IDH
Construction Log
?The secret of getting ahead is getting started. The secret of getting started is breaking your complex overwhelming tasks into small manageable tasks, and then starting on the first one.?
?Mark Twain
01-31-2016, 11:22 AM
I have some extra springs and nylon collars if you need them. Send me a PM
Dream it, Build it, Fly it
Paul Merems (EAA Tech Counselor, EAA Sheetmetal Workshop Instructor/Volunteer 12 yrs)
ExperimentalAero- HANGAR BANNERS
www.experimentalaero.com
RV-7A (Flying since 2010)/RV-4 (sold 1990)
Tucson, Arizona 85749
02-01-2016, 06:39 AM
I built everything to Van's plans and had a dragging right brake on the initial testing. And even then, I've always had to reach back in to give the pedal a tug when getting out so that I could push it up the incline and back into the hangar.
During the most recent condition inspection, after changing brake pads (third set at 273 hours; the first set broke when they got frozen by packed snow after getting real hot, fun times in MN in the winter) and the O-rings on the disk, I spent a lot of time bleeding brakes.
I was positively anal about even the tiniest bubbles and while I created a murder-scene-lookalike in the hangar a few weeks ago, the difference now is un believable.
Yes, I did the whole "springs" thing etc, but in the end, I found the best way to get the brakes to work properly is to do a better job of bleeding the lines.
