Old 01-29-2016, 01:19 PM
NavyS3BNFO NavyS3BNFO is offline
Default Spanish pilot plans around the world flight in RV-8
Saw this on General Aviation News. Might be old news to some but it will be fun to follow. Hopefully Michel Gordillo is a part of the VAF community and can give us the inside scoop on the preparation and execution.
http://generalaviationnews.com/2016/...light-in-rv-8/
RV-8 empennage DONE
Wings 99% done
Fuselage in progress
Old 01-29-2016, 01:39 PM
KRviator's Avatar
KRviator KRviator is offline
If he parks up at S'n'F for 5 days to display his -8, that's going to ruin his speed, if the article is indeed accurate.
AIUI, on an FAI RTW run, the clock never stops. You go wheels up at LAX and head west, and it's running until you touch down again a week or so later.
And C-1b isn't under 1500Kg, it is under 1,000Kg MTOW...
EDIT: Just looked at his website, he as a belly-mounted drop tank fitted to his RV-8.....And it is jettisonable!!
Once you have tasted flight you will forever walk the earth with your eyes turned skywards, for there you have been and there you will long to return - Leonardo DaVinci
My Flickr gallery: http://www.flickr.com/photos/35521362@N06/
RV-9A - Finished on 10th February 2016 after 4 years, 9 months and 19 days! The 1020th RV-9 flying.
First flight 26th March 2016. Essential specs 145KTAS @ 2400RPM, 8000', 24.2LPH, Initial RoC 1800FPM.
Last edited by KRviator : 01-29-2016 at 01:42 PM. Reason: Added the drop tank bit!
Old 01-30-2016, 05:00 AM
Steve Ashby's Avatar
Steve Ashby Steve Ashby is offline
Default Where is Michel's website
KR,
I could not find Michel Gordillo's website. Could you point me in the right direction?
Thanks!
Steve
Steve Ashby
Stone Mountain, GA
N184RW (reserved)
RV-8A
YIO-360 180 hp Lycoming
Hartzell Blended Airfoil Prop
Engine Hung
Old 01-30-2016, 05:12 AM
plehrke's Avatar
plehrke plehrke is offline
Pretty cool. Actually his route will be pretty cold but I do not know how the route qualifies as a "around the world" flight. He barely gets into the Southern Hemisphere.
Philip
RV-6A - 14+ years, 900+ hours
Based at 1H0 (Creve Coeur)
Paid dues yearly since 2007
Old 01-30-2016, 08:03 AM
gmkonrad gmkonrad is offline
website link
http://www.skypolaris.org/
Old 01-30-2016, 08:04 AM
BillL BillL is offline
This will be his third trip around the world and is planned as a pole to pole. I think the map is a previous trip. The polar route makes sense if he is gathering particulate data, as there is minimal mass flow between the hemispheres and most (vast majority) of the emissions are in the northern hemisphere. There are certainly better ways already in play to measure such things, but bravo to him for this adventure.
Funny comment on the effort - "Fight Climate Change" = burn fuel. I like it. I am looking forward to fighting it too.
Bill
RV-7
Lord Kelvin:
Old 01-30-2016, 11:02 AM
pgroell's Avatar
pgroell pgroell is offline
Default This is the trip
See this map on his website with the planned pole-to-pole trip
http://www.skypolaris.org/about/about-the-flight/
Pascal
RV-7A #72588 - F-PSGA
VAF #484 - Donated 2020
Flying
www.notreavion.net
Old 01-30-2016, 01:13 PM
KRviator's Avatar
Where he's going this time....hopefully!
Old 03-16-2016, 09:15 AM
Oliver Oliver is offline
I guess this is the correct link: http://youtu.be/_FlnMbMAGUk
Very cool clip!
* Flying Mooney M20E
* RV-10 kit on hold
Old 03-16-2016, 12:39 PM
Default Sheesh!
He has bigger cojones than I do.
Steve Ashby
Stone Mountain, GA
N184RW (reserved)
RV-8A
Engine Hung
