05-12-2015, 08:56 AM
Originally Posted by strahler13
I had a similar problem. Checked, then replaced wires to the alternator. Intermittent problem would not go away. Met Bill from B&C at Oshkosh. He told me to replace the alternator plug. I told him I checked that and the wires were fine. He said REPLACE THE PLUG. He actually gave me a new plug. We replaced the plug and no further problems.
Was it the same plug, just new? Did it have silicone plugs surrounding the wires where they enter the plug?
Bill
RV-7
Lord Kelvin:
05-12-2015, 09:37 AM
Plan Power Plug
These could be available at the local auto parts store. I got a couple on-line at www.repairconnector.com Part no. RC1650, $12.99ea.. It comes with a 6" pigtail and three butt connectors. However, the wire is PVC, not Tefzel. Could come in handy in a pinch. I potted mine with grey, sensor-safe RTV.
You can find them other places also. Google " hitachi Nippon denso oval plug".
Sam Evans
RV7-A O-360 C/S
VAF#812
11-18-2015, 12:54 PM
I just called PP to get a replacement plug and was told to order part number 11-1010 from aircraft spruce.. I went there only to find this plug and 3 wires to $105.00. what?...can that really be.?
Ryan Allen, CFII
RV7 N612RA, flying since july 2012
E-170/175
RV10 Tail Kit complete, Wings 90%, fuse on order
Acro Sport 2, building
11-18-2015, 01:02 PM
At which point I would simply giggle and mutter "Wanna bet?" and head to the workshop.
11-18-2015, 01:08 PM
Yea...I don't plan on making that purchase..
Ryan Allen, CFII
E-170/175
01-27-2016, 09:25 PM
This is also a timely thread for me.
I have a PP 60 amp alternator with the idiot light. My ammeter only shows bus amps, not total amps. My PC680 battery is only about 6 months old.
Recently I notice the idiot light showing dimly at about 1200rpm and 14 amps.
At 28 amps the light is full red but the voltage shows 13v.
At 28amps and 2100-2400 rpm the light is on dimly even though the voltage is showing 13.9-14.1
First thought was loose belt, and it was a little loose but I adjusted it to the high end of the range and no change.
It doesn't make sense to me that I show plenty of voltage to be charging the battery and yet have a red light on. How is that idiot light wired exactly?
Jim Green
RV7 tip up
IO360 Whirlwind 200RV
03-29-2016, 05:21 AM
After 550 hours I just broke the middle wire in the connector housing. Of course it would have to happen in IMC. I ordered a new crimpable connector from these guys: http://www.bmotorsports.com/shop/pro...oducts_id/1705
Paige
03-29-2016, 06:38 AM
Originally Posted by PaigeHoffart
Outstanding! Thanks, in spare time I have been looking for these parts separately. Good parts to have on hand. The inserts eliminate the wiggle and need to pot the ends!
Bill
RV-7
Lord Kelvin:
09-28-2016, 01:17 PM
Amps went to ZERO!
Well, First off...Thanks Dan for this post! I didn't think I would have to use it, but on my way to Bowling Greens this week on the way up from FL my ammeter went to ZERO
It would have been nice if the builder set his VP100 alarm to 13 volts instead of 12! I was sitting fat dumb and happy drinking from my juice box and then my scan looked at the volts going down to 12.4v and surprised me!
I cycled my alternator switch on my VP100 OFF and then back ON with a successful reset. Battery back in charging state and all was good again.
Stopped for fuel in Albany, GA....took off and then an hour from KBWG it goes back to ZERO
Another successful reset and no other issues.
Once in KBWG I pulled off the cowling, plled the pulled off and then gently squeezed the 3 sockets to be a little tighter. It seemed to feel better when I plugged it back in.
Engine run confirmed good connection. Departed back home 4.5 hours with no issues all flight!
Seems like I will be changing out the plug with a new one to be sure.
John Mastro
RV-8
09-28-2016, 02:07 PM
Good you got back ok.
http://www.driftmotion.com/category-s/1847.htm
Has (separately) the 090 sumitomo terminals, connector housing and small plugs for stain relief in the back holes. This way you can reuse your tefzel wire to the plug. They ship pretty quickly. Genuine Sumitomo too. Yes, for the ND/PP alternator.
Bill
RV-7
Lord Kelvin:
