Old 01-25-2016, 12:00 AM
Sylvainsting's Avatar
Sylvainsting Sylvainsting is offline
Default Baffle screw behind dipstick tube challenge
Hello,
Is there a possibility to put the baffle Philips screw behind the dipstick tube without remove it ? It is installed for good with some locktite and I would want to avoid to remove it..
Does somebody have a tricks for that ?
Thank you
Sylvain
RV7 QB (F-PSED), Tip Up, Aerosport IO-375, James Cowl, WW 200RV, Dynon Skyview, VP-X sport, Day VFR,
Flying...
Phase 2
Old 01-25-2016, 05:03 AM
BillL BillL is online now
Default Might be possible, but could not find a way so . . .
I just did mine and with the rivets all in the baffle and that bracket found no way to install without either bending or removing the dipstick tube. I removed the tube.
My baffles are painted and maybe wrestling with it would have worked, but I chose the easy path and no scratches.
Bill
RV-7
Lord Kelvin:
Old 01-25-2016, 06:02 AM
boom3's Avatar
boom3 boom3 is offline
I think you're going to have to remove the dipstick tube. (Easy though)
When you remove the tube, tape off the hole so you don't accidentally drop the screw down it.
Jeff Bloomquist
Sumner, WA
PP-ASEL, IR
RV-7A
Flying
1150 Hours
Old 01-25-2016, 06:26 AM
mburch's Avatar
mburch mburch is offline
I used a socket head cap screw. It's just possible to install and remove it with the dipstick tube in place, if you use a ball-end driver to get it started.
Matt Burch
RV-7 (last 90%)
http://www.rv7blog.com
VAF #836
Any opinions expressed in this message are my own and not those of my employer.
Old 01-25-2016, 07:01 AM
Default Thank you
Thank you Matt. It helps.
Do you know the exact size of this screw ? Here in France with the metric system, I have some difficulties...
In advance thank you
Sylvain
Flying...
Phase 2
Old 01-25-2016, 07:14 AM
mburch's Avatar
Sorry, I don't have the plans here in front of me, but if you look up the MS number of the Phillips head screw specified in the plans, it should be easy to figure out. I believe I used stainless, although cad-plated cap screws can be obtained also.
Matt Burch
RV-7 (last 90%)
VAF #836
Old 01-25-2016, 08:34 AM
az_gila's Avatar
az_gila az_gila is offline
Smile
It should be a MS35206-281 screw.
http://www.fastenersuperstore.com/pr...machine-screws
Get a larger #3 Phillips bit to insert the screw rather than the usual #2 bit size.
I found a bit holder for my 12 inch long 1/4 drive extension did the job easily with a torque wrench.
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
Old 01-25-2016, 08:56 AM
Thank you very much Gill for your reply.
I am happy to know there is a solution without removing the dipstick.
Sylvain
Flying...
Phase 2
