  #31
Old 01-22-2016, 11:46 AM
RBD's Avatar
RBD RBD is offline
Tail secured to large tree. Wheels chocked. Temporary fuel line taped in place. Gas can secured. Eye protection. Fingers in ears. Socks worn inside sandals for extra protection.
It didn't tip over, collapse the gear, shed the canopy (been there, done that), pull the tree out of the ground, or jump the chocks. We also didn't go crazy with the throttle. Your results may vary.
Ryan
Tampa, FL
RV-4 (sold)
RV-8 (sold)
Xtreme Decathlon (borrowing)
Old 01-22-2016, 12:24 PM
rvbuilder2002's Avatar
That is exactly what I am talking about.....
None of the things you say didn't happen, are any of the reasons I suggest not doing it.....
Scott McDaniels
Hubbard, Oregon
Old 01-22-2016, 03:35 PM
RV7A Flyer's Avatar
A couple of thoughts...
First, what compelling reason exists for doing this? I haven't heard or read any that sound good, and most seem to be just rationalizations for "I want to".
Second, this is a classic risk management exercise. What is the likelihood of something going wrong? Well, it's not zero, and based on what we've read/seen, it seems to be more than negligible. Somewhat likely? Perhaps.
The second half of risk management is the consequence should the risk actualize. In this case, the consequences can be fairly severe, including serious damage to engine and/or airframe.
At the office, we'd classify this as a 5x1 or perhaps even 5x2 (CxL) risk, which is RED and unacceptable.
So I submit there should be a really, really, really good reason for accepting this risk. Something more than "I bought this engine and I want to see it run!".
Old 01-22-2016, 04:29 PM
DaAV8R DaAV8R is offline
Default No wings
After watching the video the only advice I have is..........video tape it and be sure and put on your seatbelt
Robert Williams
Lee's Summit, MO
RV-8 - Empennage & Wings Done
Working on Fuse
O-360-A1A
1946 Cessna 120
Old 01-22-2016, 09:19 PM
nippaero's Avatar
nippaero nippaero is offline
RBD^^ That is exactly what I envisioned to do.
The real reason I asked this question is the IA who built my engine with me would like to run the motor before he sign's off the overhaul in my engine logs. I do not wish to make him wait for up to a year before I might have my wings on at the airport to run the engine to get my logs. I have the plane at home in my workshop and do not have room to leave the wings attached so they sit in the cradle. This would be a brief engine run at low RPM just to verify everything is "ok". Plane is an RV-6 with a 150hp O320.
A&P
RV-7 (Sold)
RV-6 (Sold)
1952 Cessna 170B
1947 Aeronca Chief
Old 01-23-2016, 12:29 AM
RV7A Flyer's Avatar
I'm years from doing an overhaul (I say that with fingers crossed), but...this is Experimental aviation. Is the IA's signature needed? Granted this is outside my domain of expertise, but since *anybody* can work on an experimental plane, can't you sign it off yourself if you participated in the overhaul? Is an entry in the log even required? (Not saying you shouldn't do it, but does the A&P/IA *have* to sign it?).
Old 01-23-2016, 05:34 AM
pierre smith's Avatar
Default Tailspring.
Scott, how much tension can the tail spring and attaching bolts take in pounds?
Best,
Pierre Smith
RV-10, 510 TT
Air Tractor 402 PT-6-20 Sold
Louisville, Ga
Patrick Kenny, EAA 275132
Dues gladly paid!
Old 01-23-2016, 07:54 PM
nippaero's Avatar
You are absolutely correct. It's not required but it makes a difference down the road when you go to sell the airplane and maybe the next guy will appreciate the log entries. I like to keep the logs as clean as possible.
A&P
RV-7 (Sold)
RV-6 (Sold)
1952 Cessna 170B
1947 Aeronca Chief
Old 01-24-2016, 07:26 AM
sblack sblack is offline
Why can't he wait a year?
Scott Black
VAF dues 2020
Instagram @sblack2154
Old 01-24-2016, 08:11 AM
Cyclone Cyclone is offline
Default Risk Management
I would define risk as Probability times Consequences. Extremely low probability times unacceptable consequences produces high risk! 😱
RV12 - Flying August 2019
Restoring 1967 Ford pickup - no amount
of money will make this thing fly.
"I have enough money to last me for the rest of my life.
As long as I don't buy anything"
