Old 01-17-2016, 04:15 PM
Sumo Sumo is offline
Default Time to reseal?
I've heard a few different suggestions on what to do with this, so why not ask you all for a few more
For over a year, my RV-6A (with a Lycoming O-360 and a Hartzell constant speed prop) has been 'spritzing' grease a little bit on the propeller and every now and then on the windscreen.
Today, I landed and took a look at a nice stream of grease running down just one propeller blade (link to picture below).
It was pretty cold, and it's been 2 weeks since I last flew it.
I think it's time to find a prop shop? Any good ones in Colorado?
photo here:
https://www.facebook.com/photo.php?f...type=3&theater
-Anna
Old 01-18-2016, 01:08 AM
jetjok's Avatar
jetjok jetjok is offline
Default Prop Seal
Anna,
It is likely that the seal is beginning to leak. The cold weather makes the seals less pliable, and is exacerbating the seepage of grease. Unfortunately, this is not something that your local A&P can handle, and you are correct to be seeking a prop shop.
Unfortunately, I have no knowledge of a shop local to you. If you are willing to pay the freight, I can recommend American Propeller in Redding, CA. http://www.ameritech-aviation.com I have used them for many props over the years and they do good work.
I read your FB page, and the comment that was made about the hub AD. The applicable AD is 2009-22-03 http://content.atp.com/ADs/pdf/092203.pdf
Mark Ohlau
RV-6 N506MM VAF #1410
2017 Donation Made
Old 01-18-2016, 03:40 AM
Larco's Avatar
Larco Larco is offline
This company has a great reputation in Arizona.
http://www.warnerpropeller.com
They have been around for years and would use them in a heartbeat. Larry
Old 01-18-2016, 08:50 AM
az_gila's Avatar
az_gila az_gila is offline
Smile
Maybe, but a lot of the Tucson folks send their props to Phoenix - Ottosen Propeller
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
Old 01-18-2016, 10:08 AM
DanH's Avatar
DanH DanH is offline
Assuming a Vans CS spinner kit, you have four long hub clamp bolts which also attach the rear spinner bulkhead. Loosen and re-torque those bolts and see if the leak goes away.
Dan Horton
RV-8 SS
Barrett IO-390
Old 01-18-2016, 11:34 AM
JonJay's Avatar
JonJay JonJay is offline
From my limited experience, once it starts leaking, your done. Hartzel has changed, or approved a change, to the seals. Instead of standard O-rings, you can now rebuild with a different seal. I am not sure what they are technically called, but the new seals are square shouldered with significantly more contact in the journal. They are said to be much better, but I won't know until I have a lot more hours on it since rebuild.
RV6 - Builder/Flying
Bucker Jungmann
RV1 - Proud Pilot.
Old 01-18-2016, 01:00 PM
RKorff RKorff is offline
When I first flew my RV7 with a Hartzell paddle blade prop (bought used with ~ 1000 hrs in service), it too leaked grease and I would get some spitzing on the cowl and windscreen. I loosened the retainer bolts (as suggested by Dan) and retorqued, and have flown the past 100 hrs without so much as a trace of grease from the hub. Try it, you may get lucky too.
Old 01-18-2016, 01:14 PM
TroyBranch's Avatar
TroyBranch TroyBranch is offline
What Dan said. Mine was spitting a couple of years ago and I did just that. No issues since. The bolts that go through the spinner back plate was the issue. I think the aluminum plates seat or compress over time and you loose some torque.
Troy Branch
RV10 Built and Flying Since Feb 2009
950hrs Plus
CC EX-2 Flying
SuperSTOL Built and Sold
RV9 Built and Sold
Avid Aerobat Built and Sold
Dues paid Nov 2019
Old 01-18-2016, 01:40 PM
Larco's Avatar
Maybe the Tucson people have more money?:-)
Old 05-22-2016, 02:24 PM
az_gila's Avatar
No, they lost money when props were rejected and returned stamped non-airworthy losing the ability for a second opinion.
The PHX shops did more repairs and less stamping...
Gil Alexander
