Old 01-15-2016, 08:26 AM
Larry Parham Larry Parham is offline
Default panel template
"OLD SCHOOL"
I have cut out a panel template for my 9a and I am printing out the equipment . I have found most actual colored prints, but I have not found the altimeter and the airspeed 3-1/4. Anyone know where to find???
FLOG
Larry Parham
RV-9A N65KW
2018-2019 dues paid thru June
Old 01-15-2016, 02:17 PM
JanRV6UK's Avatar
JanRV6UK JanRV6UK is offline
Originally Posted by Larry Parham View Post
"OLD SCHOOL"
What do you need ? Just the cut out template of the hole .. or a photo at the right size for layout purpose ??
Jan
Slooow RV6, no hole, builder in UK
Paid up for 2015 ...
Old 01-15-2016, 05:05 PM
Default Panel template
photo the right size for layout purpose
FLOG
Larry Parham
RV-9A N65KW
Old 01-15-2016, 08:59 PM
az_gila's Avatar
az_gila az_gila is offline
Smile
Take the two JPEGs below and use the scaling feature when you print - scale to make the diagonal distance between the center of the mounting holes 3.5 inches.
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
Old 01-15-2016, 09:12 PM
bhester's Avatar
bhester bhester is offline
Thumbs up Cheif Aircraft
Go here to find full size pics:
http://www.chiefaircraft.com/aircraf...struments.html
At the bottom of each item there are two tabs Description and Photos
Click Photos to see full size image :-)
Bobby Hester - Builder/Pilot/A&P
Surfing the web from Hopkinsville, KY
N857BH RV7A XP-O360 - Garmin G3X ADS-B IN/OUT 2020 Compliant
Web site: http://www.newtech.com/bobbyhester/RVSite.htm
Dec. 2019 VAF donator - alot better than any magazine subscription
Old 01-16-2016, 03:42 PM
Got it figured out. Thanks
FLOG
Larry Parham
RV-9A N65KW
