Old 01-11-2016, 04:47 AM
Staunch111 Staunch111 is offline
Default Stolen Aircraft Engines
Hi All, other than buying new from the factory (titan, superior, eci), can someone provide some tips on how to NOT end up buying a stolen engine. Is there a database I can run the engine case serials through. Without stripping down the internals, how do I know what is claimed to he there really is (other than buying it from a reputable engine shop (ie Penn and others). Given the cost of our engines, are they finding their way to.unscrupulous sellers. Are there any persons/ shops you would avoid. Any comments would be greatly appreciated.
Old 01-11-2016, 07:24 AM
Xkuzme1's Avatar
Xkuzme1 Xkuzme1 is offline
Default ...
I would think that if you were buying a used engine, making sure the logs accompanied the engine would be the best way. I wouldnt imagine that a new engine would easily find itself in the hands of a thief.
X
RV-4 - 0-320 (160HP)
www.KCFlight.org
Tinker
ATP/CFI/II/MEI
N617TN
Old 01-11-2016, 07:32 AM
bret's Avatar
bret bret is offline
Ditto above, the engine I just bought has three logbooks dating back to 1964, and the prop has log books. These also have the Aircraft N # that you can verify with the FAA.
Old 01-11-2016, 07:48 AM
All well and good if there are log books, but then there are a number of engines (you know removed from cessnas and like) now sitting on the hangar floor either with 1500hrs or as cores with no logs. How do I check?
Old 01-11-2016, 08:08 AM
Raymo's Avatar
Raymo Raymo is offline
If buying as a core engine, you will be sending it off for OH, which will generate a new logbook. Without knowing the history of the engine, you would want the OH to provide a zero time engine so its new life is properly documented. An OH to minimum specs does not zero the engine and you would not know how many hours with which to start the logbook.
Ray
Old 01-11-2016, 08:21 AM
cderk's Avatar
cderk cderk is offline
Wow - this is pretty amazing... had no idea there was a problem with stolen aircraft engines in the marketplace.
RV10
http://n688cd.wordpress.com
Old 01-11-2016, 10:03 AM
See my understanding. Joe Blow rocks up, bolts off 3 engines at a quiet field -100k down the tube. Assuming their insured- fine. But if New engines, the relevant maker can provide serials for all internals thereby limiting the reuse of such parts in an,above board shop. But looking around and buying privately off say Barnstormers- I really could be buying anything.Hence my reluctance to source privately and while ill most end up paying top dollar for a new engine
Old 01-11-2016, 01:24 PM
Charles C's Avatar
Charles C Charles C is offline
Default Another option
Another option you could do is call your local law enforcement agency and provide them with the serial number off the engine. I work in Law enforcement and if something like an engine has been stolen and the owner/reporter has the serial number it would be entered into a national data base. If the serial number is run by another law enforcement agency the serial number would pop up as a stolen item.
Just an idea....
Charles & Fran Cantrill
RV-6A - SOLD
Piper Comanche PA-24-250 - SOLD
RV-7A - Sold
Progressive Aerodyne Searey - SOLD
Orlando, Fl.
Flying out of Grass Roots Airpark (O6FD)
ASEL Commercial/Instrument
Commercial Helicopter
Paid 2018 Dues Gladly Paid
Old 01-11-2016, 01:34 PM
YellowJacket RV9 YellowJacket RV9 is offline
I did a quick google search for "stolen lycoming engine". Not a whole lot comes up. Plenty of stolen airplanes, but very few stolen engines. Not that it doesn't or couldn't happen, and I'm sure somebody will chime in with a story about how it happened to them, but it's not something I would have worried too much about, especially because I bought an engine out of a flying RV.
If you're buying an engine from somebody who has it in a basement, knows little about it or it's history, or otherwise seems sketchy, I would pass for a number of reasons. There are plenty of reputable people and places to buy a used engine, I wouldn't be overly concerned with this.
Chris
Chris Johnson
Old 01-11-2016, 02:49 PM
RVDan RVDan is offline
Chris
A lot of stolen airplanes are broken down into parts that are untraceable. The engine is likely also broken down so it is not traceable. A club I was part of had an airplane stolen. No trace of the airplane or the engine, the main things with recorded serial numbers. 2 years later an ex member of the club was arrested for parting out airplanes. He would fly them into his farm, put them in his barn and strip down for parts sales. Pretty sure that is where our airplane went.
Dan Morris
Frederick, MD
PA28-140
Hph 304CZ
RV6 built and sold
N199EC RV6A flying
Learn the facts. "Democracy dies in darkness"
