Old 01-05-2016, 10:07 PM
6adan 6adan is offline
Default 6A nose wheel problem
I am just getting to the point of putting the nose wheel on my project. The problem I ran into is the wheel with bearings and spacers are right at 7/32 wider than the wheel fork. I have the old fork and the new redesigned and they are the same inside width. Has anyone else had this problem and what did you do about it?
Thanks Dannie
Old 01-05-2016, 10:36 PM
gasman gasman is offline
Just jack it apart a little...... Mine was the same.
VAF #897 Warren Moretti
2019 =VAF= Dues PAID
Old 01-06-2016, 05:59 AM
noelf noelf is offline
Same here. Just spread the forks apart.
Noel
RV-6A N6NF
tip-up
flying
Old 01-06-2016, 09:12 AM
OK will do.
Thanks again.
Old 01-06-2016, 10:01 AM
AlexPeterson's Avatar
AlexPeterson AlexPeterson is online now
Anyone messing with nose wheels should perhaps read this.
Alex Peterson
RV6A N66AP 1700+ hours
KADC, Wadena, MN
Old 01-06-2016, 10:34 AM
rvbuilder2002's Avatar
First thing I would check is to make sure the two wheel halves are fully seated on each other (that the tube is not pinched between the wheel halves).
Scott McDaniels
Hubbard, Oregon
Old 01-06-2016, 11:05 AM
ChiefPilot's Avatar
ChiefPilot ChiefPilot is offline
Alex is spot on with this.
While I was not a fan of deviating from Van's plans when building my -6A, I did ditch the aluminum "donuts" and went with a real axle instead. I had already installed the donuts but not yet flown. The axle was easy to install (under an hour for sure) and the nose wheel rolled much more easily and smoothly afterwards.
Brad Benson, Maplewood MN.
RV-6A N164BL, Flying since Nov 2012!
If you're not making mistakes, you're probably not making anything
Old 01-07-2016, 08:07 AM
morganjp morganjp is offline
Smile
I bought the Berringer nose wheel with the tubeless tire and through axle that the axle bolt slides through. It is a great improvement!
John Morgan
John Morgan
Atlanta, GA KPDK
N613SC
RV6A -SMILIN 1
Old 01-07-2016, 09:01 AM
Thanks everyone. Now I have even more things to thank about.
Old 01-07-2016, 11:28 AM
Raymo's Avatar
Raymo Raymo is offline
The Berringer nose wheel is very nice... and expensive. Grove also carries similar options.
Ray
