Old 12-29-2015, 04:52 AM
RFazio RFazio is offline
Default Manual to electric flaps on an RV-4
My buddy wants to change his 4 over to electric flaps. I see vans sells two kits for this. One uses the original weldment, and the second uses a new weldment. The second is more expensive of course. Has anyone done this with these kits. They don't show very good pictures of the kits. I can't really tell how they are different. I can't see how using the original weldment would work. Any info on this would be appreciated.
Richard
Richard Fazio
LI, NY
N966RV
RV-6 Slider
O-360
FP Wood Prop
Old 12-29-2015, 05:56 AM
RogerG RogerG is offline
Richard,
The original manual weldment does have to be modified. I can't remember the details, but it seems it was outlined pretty well in the 27 years of Rvaviator. If you have the PDF of Rvaviator, you should be able to do a search.
http://vansaircraft.com/cgi-bin/stor...uct=rvator-yrs
Roger Graham
Lubbock TX
RV-4 Under Construction
VAF Dues Paid 2018-2019
Old 12-29-2015, 08:45 AM
clevtool's Avatar
clevtool clevtool is offline
I have done it with the retrofit weldment. Keeps from having to cut and weld on original if I recall. It was straightforward and is a great improvement. I put the switch on the bulkhead just in front of the throttle for easy reach. The worst part was doing all the work between your feet. Doing it again I would make sure to have a helper to run for tools, and set up a scaffold even with the longeron and perpendicular to the fuse. to lay on. I seem to remember breaking a lot of angle drill bits for some reason.
Mike Lauritsen
Cleaveland Aircraft Tool
800-368-1822
www.CleavelandTool.com
mike.toolman (at) gmail.com
Like on Facebook - Follow on Twitter - See on YouTube
Old 12-29-2015, 10:13 AM
SMRacer SMRacer is offline
Default RV8 style
Or you can do it the easy way. It is still necessary to weld the two brackets on the original lever. I had intended to connect the motor to the black bracket, but the geometry didn't work. (mainly because I didn't use the Van's motor assembly). So the additional bracket was added to insure the motor would free wheel at both full extend and full retract.
Jim
Old 12-29-2015, 10:46 AM
rbibb's Avatar
rbibb rbibb is offline
Originally Posted by SMRacer View Post
Jim
This is a much improved design (more like the RV-8 implementation) that the RV-4 design, IMO.
If I was doing this I would go this route. I did the RV-4 retrofit using the factory modified weldment and it is a it of a pain but doable. This would be easier to install as the access is much easier.
Richard Bibb
RV-4 N144KT
Fredericksburg, VA
KEZF
Old 01-28-2016, 05:16 AM
Jim
Jim can you comment on what motor actuator assembly you found to work for this application? Nice easy setup. Thanks for sharing.
Roger Graham
Lubbock TX
