  #11
Old 09-19-2015, 11:04 PM
rvbuilder2002's Avatar
Originally Posted by magiccarpet View Post
I can not say how the whacky hammer method would have worked out, but I can say that I am glad to have used the dies for it.
The wacky hammer method actually works quite well as proven by the 9000+ RV's that have been completed and flown....
Up until only recently, if you were building an RV that required curved longeron angles (pretty much all of them until the RV-14), it was the only way.
Scott McDaniels
Hubbard, Oregon
Old 12-21-2015, 06:09 PM
kevinl4000's Avatar
kevinl4000 kevinl4000 is offline
Default Borrow Your Longeron Dies?
Does anyone have the RV-12 Longeron dies I could borrow/rent? I'll return them in good condition quickly, within 5 - 10 days or so, cover your shipping, and include a little extra $ as a way of saying "thanks!"
Appreciate it.
Kit #120-666 "The number of the beast"
http://kevinsrv12build.blogspot.com
Old 12-23-2015, 09:15 PM
waterboy2110 waterboy2110 is offline
Kevin,
I'm in KCCR - you can drive down or perhaps I could fly to KSAC (was there on Monday). Send me a PM and let me know if you need them.
http://jimsrv.blogspot.com
PP - ASEL
Instrument Rating
A&P/IA Rotax iRMT 9 Series Maintenance
EAA Technical Counselor
RV12 Flying.
Old 12-23-2015, 11:18 PM
gossend gossend is offline
Default Vans longerons are designed to weed out the sissies
All it took for me was a set of dies, an eight inch chinese vise, a four pond sledge, a 12 inch crescent wrench and a ten ton hydraulic press. Piece o cake!
...and an unnecessarily difficult step in an otherwise fine kit design.
Universally hated, this critical and difficult step should have become factory-formed long ago. Seems to be part of the smug cultural attitude exhibited in other areas - like failure-prone nose struts, and main gear shimmy on tail draggers. I'm fairly new to the community, so maybe I just don't get it about this stuff....or maybe I'm just a sissy!
Dick Gossen
gossend@gmail.com
Flying: EAB RV-12 with Aeromomentum AM15-HP engine
Old 12-24-2015, 03:35 AM
kevinl4000's Avatar
Originally Posted by waterboy2110 View Post
Kevin,
PM sent. Thank you!
Old 12-24-2015, 04:50 AM
longranger's Avatar
Originally Posted by Brantel View Post
A vise, dead-blow hammer and a crescent wrench does wonders with longeron forming.
You don't even need the hammer. Clamp both longerons back-to-back along the horizontal faces, lay 'em in the vise every few inches (no need to tighten the vise), and lean on 'em. The curves in mine came out within the width of the template line, and were identical mirror images of each other.
http://mykitlog.com/users/display_lo...186428&row=104
RV-7 TU 904KM (reserved)
Construction Log
