05-31-2014, 06:01 AM
I would prob have taken you up on that a few days ago but have since ordered the 1.5 qt 23903.
How many seconds are you guys seeing out of the 1.5 qt units with no check valve? I also have an inverted system with my valve mounted as stated above but, for a non-aerobatic prop, there is too much of a delay in the transition from normal to inverted operation and during zero G of more than 3-4 seconds.
05-31-2014, 07:15 AM
I get about 6 or 7 seconds of pressure with a 1.5 quart accumulator.
Ron Schreck
IAC National Judge
RV-8, "Miss Izzy", 2250 Hours - Sold
VAF 2021 Donor
05-31-2014, 03:10 PM
I just ordered the check valve... seems simple to install and will direct oil in one direction to the engine.
Mike
RV-4 #2750
N654ML
IO-360
WW150C Prop
1018 lbs
Flying
08-22-2015, 01:03 PM
Pressurized Oil Accumulators - where to install
Hello,
I bought the Moroso 1.5 QT. accumulator for my RV7A project.
Where do you recommend to install this unit?
My first idea was to install it on the firewall on the side of engine.
Witold
08-22-2015, 01:32 PM
Originally Posted by witek
Hello,
Witold
You can put it anywhere you want. Many aerobatic planes have it in the tail if they need weight back there. Of course the hose would be expensive, but the length of hose is not an issue otherwise.
Ron Schreck
IAC National Judge
VAF 2021 Donor
12-21-2015, 02:28 PM
Pressurized Oil Accumulators - how to install
Hello,
Moroso 1.5 QT. accumulator in RV7A - which oil line the accumulator should be connected to?
Moroso recommends to install T-piece on oil line from oil cooler to engine - is it correct installation on Lycoming IO360?
Photos of existing installation would be very helpful for me :-)
Witold
12-21-2015, 03:25 PM
Hello,
Witold
You connect at any point. I put a T-fitting at the oil cooler exit.
Ron Schreck
IAC National Judge
VAF 2021 Donor
12-23-2015, 01:23 AM
Thanks Ron,
In my application would be easier to connect T-piece on the oil line from engine to cooler (this one which is located lower on Lycoming 360 engine). But I'm afraid if this option will work correctly due to the fact that this line is very close to oil sump - it means if oil pressure in engine drop, the oil from accumulator can go to sump instead of to engine. ??? But I'm not sure if it works in this way.
Witold
12-23-2015, 05:53 AM
Thanks Ron,
Witold
That's a pressurized line too. It will work.
Ron Schreck
IAC National Judge
VAF 2021 Donor
12-23-2015, 06:24 AM
Accumulator Video
I'm actively researching these for my -4. Here's a good video of a 3 quart unit in action - https://youtu.be/vyaGoj60A6s
Too big for an RV but a good demonstration of operation.
Randy King
Tampa (Wimauma), Florida
RV-4 N212CS (sold)
RV-8 N184RK (flying)
Flying an A320 to pay the bills
Exempt and gladly donating anyway - Current through March 2021
