  #11
Old 10-30-2014, 05:10 PM
dick seiders dick seiders is offline
Lots of questions and it's a bit early, but will answer as best I can at this point.
1. Commercially? Don't know, but maybe.
2. Cost? To be determined.
3. 11 lbs more than riveted tank. The 5052 is .090" for added strength.
4. The sending unit is placed on the top of tank towards the rear. In this way the sending unit could be repaired/replaced w/o removing tank.
5. Yes to the baffles, the reinforcing doublers, and the return line brackets as well.
6. Coupling is welded on bottom for the feed fitting. A threaded block is welded inside the bottom to lock the return line fitting in place.
7. You didn't ask, but the flange for the fill line, and a coupling for the alum. tubing to vent line is also welded.
8. I am still working on sending photos.
note: tank sealant is required only on the sending unit and the T1209 door. the Moller gage, and the two fittings on the bottom.
Dick
Old 11-04-2014, 02:34 PM
Tony_T's Avatar
Tony_T Tony_T is offline
Default Photos of Dicks Welded Tank
The photos show the details well. Please direct any questions to Dick:
Tony
E-LSA RV-12 ULS
Old 12-20-2015, 04:17 AM
KALEWIS's Avatar
KALEWIS KALEWIS is offline
Default Any updates?
Any updates as to cost and/or will these be available for purchase? Just finishing a new tank build using parts from the old "seeping" tank. Going new got rid of the sight window as well. Not a fan of sealant and rivets . ZENITH offers welded tanks..... Will VANS ever consider this? No idea.
Video shows a welded tank from Zenith.
http://www.eaavideo.org/video.aspx?v=3617603499001
Airspeed, Altitude, or Brains...you need at least two
RV-12 #328
At 630 Hrs on the Hobbs
Old 12-20-2015, 07:26 AM
Piper J3's Avatar
Piper J3 Piper J3 is online now
Wrong thread...
Jim Stricker
EAA #499867
Bought Flying RV-12 #120058 Oct 2015 with 48TT - Hobbs now 618
Old 12-20-2015, 03:49 PM
Hotscam Hotscam is offline
I welded mine from 0.05 to keep it light.
Works well for 500 hours but it does not look so well as yours.
How did you prevent the heat buckling ? It looks perfectly straight
Jack Netherlands
PH-SEP and PH-SES
RV12 #120519 and #120790
Hobbs 700+ hours and 400+ hours
Dual SV1000 Skyview 15, Pocket FMS and Powerflarm 6.0 (ADSB)
RV10 PH-USN Hobbs 350 hours
Old 12-20-2015, 09:43 PM
sblack sblack is offline
Usually tanks that size have beads rolled in the for rigidity and flange welds on the ends which give more rigidity. You can use geometry for strength rather than thicker material. This helps with the heat disortion. In WWII it was common to braze the fittings on to avoid distortion as the brazing temps are much lower than the melting point of the patent metal.
.09" is much heavier material than most fuel tanks in airplanes, but 5052 is a standard material for tanks because of its corrosion resistance and because it welds readily. This could be made from 0.050" material quite easily.
Kent White has written numerous articles on welded tank construction. A good one was in Home Shop Machinist a coule of years ago. He gas welds everything....old school.
Scott Black
VAF dues 2020
Instagram @sblack2154
