Originally Posted by mosquito
A 'stroker' O-340 with the Titan crankshaft should be a direct replacement for your O-320, same size and weight, but with O-360 power (180hp). That's what I intend to replace my O-320 with one day (hopefully in the very, very distant future).
-jon
I have converted my RV6 from an O-320 (160 HP) to and O-340 Stroker (~180 HP). My RV6 is "old school" and has the tight O-320 cowl so an O360 carb would NOT fit.
I have had issues with the originally supplied 340 carburetor (M-S Experimental for the 340). I didn't like the EGT spread. Lots of work with ECI to get it dialed in but we decided that I would change over to fuel injection.
Working with Don at Airflow Performance on a new fuel injection product for the 340 that will fit within the tight O-320 cowl of the earlier RV6's if that is what you have. (This should fit in some of the tight RV4 cowls as well, I believe.)
We hope to have some data in a week or so that can be shared. If not then right after the holidays. Test flight with the prototype (and resultant data) showed significant improvements. The engine pulls STRONG!
Now, if your cowl is the later/larger cowl that accommodates the 360 then you are probably good to go.
James
