5.7.8
External Standby Input
This input, when held low, places the transponder in Standby mode. It should be used to switch between transponders in an installation with two transponders. The input is active low, and will be asserted when the voltage to ground is pulled below approximately 4 Volts
Walt Aronow, DFW, TX (52F)
EXP Aircraft Services LLC
