Old 12-09-2015, 01:49 PM
Ron B. Ron B. is offline
Default Drilling AN bolt
I received an AN7-21A bolt rather than the AN7-21 called for. Any issues drilling into the threads of an AN7 bolt for a castle nut cotter pin?
Thanks Ron
RV-10 SOLD
RV-14 Flying
AirCam flying
Old 12-09-2015, 03:00 PM
krw5927 krw5927 is offline
One idea for accomplishing your goal:
http://www.mtfca.com/discus/messages...tml?1351279141
Because you will be drilling the hole and cleaning up the threads after the cadmium plating operation, the areas where you remove the yellow cad plating will corrode much faster than a standard AN7-21 bolt. Whether or not this matters is a choice only you can make.
Kurt W.
RV9A
FLYING!!!
Old 12-09-2015, 03:02 PM
Good way to break a drill bit - been there done that.
RV-12 Build Helper
RV-7A...Sold #70374
The RV-8...Sold #83261
Old 12-09-2015, 05:57 PM
I drilled it and cleaned up the threads. It's at a very visible location and easy to keep an eye on.
Thanks Ron
RV-10 SOLD
RV-14 Flying
AirCam flying
Old 12-09-2015, 06:14 PM
BillL BillL is offline
I have done many this way. Just have to be careful the drill bit goes straight, the small ones drift off easily. I drilled each side of the nut separately for that reason.
Bill
RV-7
Lord Kelvin:
Old 12-10-2015, 05:19 AM
JanRV6UK's Avatar
JanRV6UK JanRV6UK is offline
Good idea to use some cutting oil as well .. any oil is better than trying to drill dry ..
Jan
Slooow RV6, no hole, builder in UK
Paid up for 2015 ...
Old 12-10-2015, 03:08 PM
When you install it, put a dab of grease on the cotter pin, and you won't have a corrosion problem.
Doug
RV-9A "slider"
Tail number N427DK
Donation made for 2020
