12-08-2015, 05:58 PM
Good idea
Originally Posted by Pat Stewart
I seem to remember an old discussion about the gasket for the prop governor and that it can be installed wrong and cause similar issues. This is just a guess and may not add any value.
Good thought and not hard to check. But seems to be unlikely if your other tests were right. I would check this anyway.
Dale
ATP, dreamer and maintainer; but not a builder
RV6a N18XP 960TT (builder: Jerry Cochran)
RV6a flight experience 2100 hrs
Superior IO-360 2007
Hartzell Blended Airfoil Prop
Dual LS EI, Dual Battery
GRT HX efis & RAIM GPS, 2 axis GRT autopilot
G696, GDL39 WX, Traffic
Dynon D10
Gear Leg Stiffeners from Woodmanrog
12-08-2015, 06:07 PM
Senior Curmudgeon
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
12-09-2015, 07:13 AM
If you have an internal leak in the oil pressure system, after the pump, the oil pressure should be low at idle and get improved as you increase engine and pump RPM. Your oil pressure is going down with increase in rpm with the prop governor removed and the nose bearing cavity in the crank blocked off. So to me you have eliminated all prop related issues. To me, your sequence of events doesn't suggest an internal leak. Oil pressure is going down with additional engine and pump RPM... not up. Blockage to the oil pump supply can cause good idle pressure and decreasing oil pressure as pump rpm is increased. So, my thought is there may be blockage to the oil pump. you sure a rag didn't get into the sump while doing the conversion? To me, something is causing the oil pump to have less efficiency when rpm is increased, ie inlet blockage, slipping drive etc.
Good Luck,
Mahlon
"The opinions and information provided in this and all of my posts are hopefully helpful to you. Please use the information provided responsibly and at your own risk."
12-09-2015, 08:22 AM
I have worked on a lot of engines, in cars, bikes, boats and now airplanes. 9 times out of 10, when you just modified it and find something not working right....something odd happened in the change. Like Mahlon said, a rag left somewhere or a bolt that dropped and just happened to go into a supply line. Something weird that you couldn't do on purpose, but managed to happen on accident. Before you pull the engine and split the case....just be sure you haven't assumed anything. Pull it all back off and look it over.
RV-8 Flying
1,235th flying RV8
SARL Race#95
SnF Homebuilt Judge
12-09-2015, 09:19 AM
Pulling the large oil screen in the sump might be a good first step to looking for a partial blockage...
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
12-09-2015, 11:29 AM
I'm with mahlon_r's theory. At your second point, I was thinking that something is blocking the oil from getting to the pump. Pull a mag and borescope and/or pull the screen and borescope.
Ray
12-09-2015, 04:03 PM
Thanks for the suggestions. I'll take off an accessory or two and see what my my Chinese bore-scope may find. I did pull the oil screen in the sump to check it and it was clean as a whistle. This is definitely the time to take things slow. Especially with the cold Maine winters.
Claudio Scremin
N221Z RV8A Maine 600+ hrs
12-09-2015, 08:44 PM
This may be tough, depending upon your sump. My sump, from a D model, had a round chamber holding a cigar-like screen. There were two rectangular cutouts connecting the filter chamber to the main sump. If you can get a flashlight or small mirror in there, you may be able to see a blockage, otherwise, with that style pan, the major blockage would be in the main sump on the other side of the chamber wall, requiring sump removal for inspection.
Larry
12-11-2015, 06:31 AM
With a bore scope, I have had some luck going in through the oil filler tube to have a look inside of the engine case.
12-11-2015, 06:39 AM
Talk to a prop shop! Tell them what you did and ask them if they have ever seen this occur, they have likely had this or a similar occurrence and have a good idea where to look. If they have been in business for a long time and you get the guy who has been there for 30 years he can say yes or no to each probable prop / governor individual issue.
