Old 12-06-2015, 06:30 PM
ChiefPilot's Avatar
ChiefPilot ChiefPilot is offline
Default IFR Sunset
I went for a short IFR currency flight from KSGS to KSTC and back today; KSTC was reporting 200' and 1/4 mile viz so I knew I would be going missed but wanted the practice. Tops were 2500 and I was cruising back at 4000' when the sun set. Scenes like this are one reason why I love to fly.
Brad Benson, Maplewood MN.
RV-6A N164BL, Flying since Nov 2012!
If you're not making mistakes, you're probably not making anything
Old 12-06-2015, 06:37 PM
blueflyer's Avatar
blueflyer blueflyer is offline
beautiful.
Old 12-06-2015, 06:43 PM
Latintan's Avatar
Latintan Latintan is offline
Very nice....
Manny Oro
RV-6/A
Old 12-06-2015, 08:24 PM
wjb's Avatar
wjb wjb is offline
Sweet! Thanks for sharing.
Bill Bencze
N430WB RV-7 @KHAF, Flying 100+ hrs
VAF 2021 donation happily made
Old 12-06-2015, 08:27 PM
Gorgeous view! Any freezing moisture on the way down?
Old 12-06-2015, 08:55 PM
ChiefPilot's Avatar
Negative icing. Aside from that, I was only IMC briefly as tops were at 2500' and the MDA was 1219. OAT on top was 5?C.
I like to shoot ILS approaches at 135kts, so when I went missed I popped back out of the undercast pretty quickly.
Old 12-07-2015, 09:18 PM
xblueh2o xblueh2o is offline
I remember years ago one winter day shortly after I got my IFR ticket I went out to a nearby airport (Modesto for the Northern Ca group) that was reporting indefinite ceiling 200, 1/2 mile vis with an IFR rated buddy of mine acting as safety pilot. Like your flight, the tops were up around 2000 and clear above but I wanted to actually see, or not see, what it was like to arrive at mins and have nothing there. I wanted to see it for real.
At the time Modesto had and NDB approach, a VOR approach and an ILS. I shot two of each type of approach. I didn't see anything for the NDB or VOR approaches. The VOR was a VOR/DME approach so when you were on course and at the correct distance you were right over the threshold which was only 400' below you but there was nothing to see. When I shot the first ILS we just caught a glimpse of the rabbits after we committed to the missed approach. The second one we could have made it in. The approach lights and the red bars grew out of the murk at mins so we technically could have gone down to 100' but it was time to get the rental airplane back home. Flying home after that last approach looked just like your picture.
Sam
RV-8 with the Showplanes Fastback conversion
Emp completed except for glass work
Wings completed except for bottom skin and glass work
Fuselage underway
N18451 reserved
Old 12-07-2015, 10:06 PM
AlexPeterson's Avatar
Brad, very nice picture! Is the bump in the clouds the Becker power plant's plume?
Alex Peterson
RV6A N66AP 1750+ hours
KADC, Wadena, MN
Old 12-07-2015, 10:24 PM
ChiefPilot's Avatar
Yes, it is - I found the patterns from local flow disruption pretty interesting. The wind was from the NW, and you can see how the plume and the wind interacted on the surface of the undercast. There was a similar thing going on with the stack from the plant near Stillwater as well.
Old 12-08-2015, 07:34 AM
BillL BillL is offline
Default It is icing time of year.
I am a bit south of MN, but had 32F and fog yesterday morning. I drove to town, and on the way back noticed the antenna in an excessive primary bending mode with 18" tip to tip at 50 kts. WHAT?? Yes, it was ice. Stopped cleaned it off and back to stability. Those little spirals to eliminate trailing vortices (and all that excitement) are very effective.
Bill
RV-7
