Old 11-30-2015, 09:35 PM
nippaero's Avatar
nippaero nippaero is offline
Default Preferred way to cover up firewall holes
I had to relocate my brake reservoir and need to plug a couple holes. What is the best way to plug say a 1/4" and 1/2" hole? Rivet a plate over them?
A&P
RV-7 (Sold)
RV-6 (Sold)
1952 Cessna 170B
1947 Aeronca Chief
Old 11-30-2015, 09:55 PM
Walt's Avatar
Walt Walt is offline
Bolt with large OD washer as required.
Walt Aronow, DFW, TX (52F)
EXP Aircraft Services LLC
Old 11-30-2015, 09:56 PM
cfiidon's Avatar
cfiidon cfiidon is offline
Default Hole filler
Bolt, washer, nut.
Don
RV-8 QB Titan ECi 191HP XIO-360
WW200RV Dynon D180 HS34 AP74
GNS430 SL30 GTX327 PS8000B Uavionix Echouat
"Pilots are alchemists... we turn gold into lead."
Old 11-30-2015, 10:41 PM
RV7A Flyer's Avatar
Old 12-01-2015, 04:46 AM
rmartingt's Avatar
Originally Posted by RV7A Flyer View Post
In your firewall?!
As other stated, bolts and washers are a much better choice.
Old 12-01-2015, 10:26 AM
sblack sblack is offline
If you pop rivet a stainless plate in place, use stainless rivets for fire protection.
Scott Black
VAF dues 2020
Instagram @sblack2154
Old 12-01-2015, 10:57 AM
RV7A Flyer's Avatar
Originally Posted by rmartingt View Post
In your firewall?!
Actually, yes, for my firewall. In the hole that is drilled to provide access to the bolt on the nosegear (with a fillet of RTV for CO protection). Per Van's:
SS FIREWALL PLUG
FF 3/4 FIREWALL PLUG
It is, after all, stainless steel.
Old 12-01-2015, 12:38 PM
AttackPilot64 AttackPilot64 is offline
Default hole covers
Were can i get these from ??
Old 12-01-2015, 01:49 PM
aerhed aerhed is offline
Hardware store. I use the fireblock caulk to seal them.
Actual repeat offender.
Old 12-01-2015, 05:32 PM
8 ball 8 ball is offline
Talking
Lowes has the stainless plugs
