Old 11-22-2015, 02:32 PM
cmgolden cmgolden is offline
Default RV-10 Service Ceiling
I went flying this morning on a cold and beautiful day over Wichita. I headed Northwest and climbed to check the airplane's service ceiling. 40 minutes later I still wasn't quite to the ceiling, but I think I got pretty close.
Cutting to the chase: I flew to 23,000 feet and still had a bit more to go. I could have gone another 1,000 feet without trouble. And I achieved my personal best ground speed coming back: 255 knots.
Details:
On departure I climbed at about 115 kts doing 1,300 feet per minute.
By 7,000, that rate declined to about 1,200 fpm.
At 10,000 feet, I was climbing at 900 fpm at 115 KIAS.
At 16,700 feet, I climbed at 500 fpm (slowing airspeed to 110 KIAS)
At 19,400 feet, I saw 400 fpm (at 95 KIAS)
At 23,000 feet, I was still doing about 200 fpm (95 KIAS)
I had already asked for higher than my original flight plan (FL220) and the controller sounded like he had someone at 24,000 that would pose a conflict if I continued, so I ended my climb at FL230.
When I turned around and began my descent, I benefited from the 77 knot tailwind at that altitude and I achieved my personal record 255 knot ground speed.
Overall, it was an interesting flight.
Chris G.
RV-10 w/EFII
Wichita, KS
Old 11-22-2015, 02:54 PM
Jesse's Avatar
Jesse Jesse is offline
I wonder if the EFII system had an effect on the performance and being able to get up that high. I assume you were lightweight, but the highest we have been is almost FL220.
Jesse Saint
Old 11-22-2015, 03:03 PM
Two big variables are weight (sounds like you were solo) and temperature (density altitude). You mentioned that it was cold.
Old 11-22-2015, 04:23 PM
Default Light
Indeed I was solo. Outside air temp at FL230 was -24C (which is a bit warmer than standard, I think). I had about 40 gallons at altitude. Density altitude was not quite FL240.
Chris G.
RV-10 w/EFII
Wichita, KS
Old 11-23-2015, 05:59 AM
bruceflys bruceflys is offline
Excellent data, thanks. How did you obtain and post such a clear screenshot of the Dynon display?
Bruce
Panther - Building 2019
RV-12 - Flying 2016; Sold 2018
RV-10 - Sold 2018; Flying 2018
SeaRey - Flying 2012; Sold 2017
Old 11-23-2015, 06:04 AM
Jesse's Avatar
There is a keystroke to capture a screenshot from the screen itself. Very useful for this type of thing. I can't remember the keystroke, but it can be done.
Edit: Ensure a USB memory stick is inserted into one of the USB ports and press and hold the #2 and #7 keys.
Jesse Saint
Old 11-23-2015, 03:53 PM
RV10inOz's Avatar
RV10inOz RV10inOz is offline
Interesting flight.
My typical load would be more than that by about 330lbs and at that I have found FL170 is about the limit of "practical" in terms of time to climb, efficiency of the flight etc.
Most of the time FL150 is my maximum.
David Brown
Old 11-23-2015, 05:52 PM
I'll bet density altitude is routinely on the high side?
Old 11-24-2015, 08:38 PM
JDanno JDanno is offline
Can you tell us what kind of hoops (FAA or others) you had to go that high? Any special training? Had to use a pressure O2 mask? Etc. thanks!
Pretty cool feat of daring!
Old 11-24-2015, 08:49 PM
Just the obvious things, I think:
IFR rating and ifr clearance
oxygen via mask (canulas limited to 18000') but no pressure mask needed.
(you need a pressure mask when ambient pressure, 100% O2 is not enough. Since sea level O2 partial pressure is about 20% of one atmosphere, you have to go up to where the air pressure is 0.2 atmosphere - like FL400 or so - before you need a pressure mask.)
