Old 11-21-2015, 06:45 PM
Taildrgr's Avatar
Taildrgr Taildrgr is offline
Default Exhaust Hanger Broken
During my preflight I grab the exhaust extension below the cowl exit and give it a good shake.
At 16 hours into Phase I, my right pipe was loose.
Looking into the cowl exit with a flashlight showed a broken exhaust hanger.
My hangers are connected to the engine sump so the exhaust moves with the engine.
I called Clint at Vetterman Exhaust and he said the hanger tubes can break if they are bent for fitting during installation.
As can be seen in the pics, mine is not bent.
Clint also said they have had some rare breaks for unknown reasons, perhaps a defect in the crimped end.
I think I will move the cross piece up a bit to make sure it does not rub on the nose gear mount.
Anyway, I replaced the hanger tube and will continue checking them during preflight.
Just wanted to give a heads up to all about checking those exhaust hangers.
I put the hanger back together for this picture.....
Bob B
RV-7A Sold
RV-4 Sold
DFW TX
Dues Paid
Old 11-21-2015, 06:51 PM
The components in the exhaust hangar system break frequently. I carry a spare set in my fly-away kit.
Kyle Boatright
Marietta, GA
2001 RV-6 N46KB
2019(?) RV-10
Old 11-21-2015, 08:18 PM
Infidel's Avatar
Infidel Infidel is offline
A little jiggle on the exhaust pipes is always a part of my preflight and glad to see others (you) doing it as well.
Old 11-21-2015, 08:45 PM
LifeofReiley's Avatar
LifeofReiley LifeofReiley is offline
It does happen, a lot going on in this area.
Reiley
Retired N622DR - Serial #V7A1467
VAF# 671
Repeat Offender / Race 007
Friend of the RV-1
Old 11-21-2015, 09:22 PM
Sam Buchanan's Avatar
been here awhile
Default Been a problem for as long as RVs have had exhaust systems
Been flying my RV-6 for 16 years and broken exhaust hangars were a known issue when my plane was new. I carry a length of steel automotive brake line in the flight kit so a new hanger can be fabricated on short notice. Fortunately a broken hangar usually won't keep you from flying the plane home.
Sam Buchanan
RV-6
Fokker D.VII replica
Old 11-21-2015, 09:24 PM
az_gila's Avatar
az_gila az_gila is offline
Smile
That's a good case for installing the bolts in a "backwards" from standard fashion with the nuts facing out.
Would make a replacement easier with less clamping tools involved in the field.
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
Old 11-22-2015, 06:14 AM
Taildrgr's Avatar
Hopefully, this won't be a recurring problem every 16 hours, but I did order 2 extra hanger pieces from Clint just in case!
It only took about 20 minutes to change it out.
Good idea to put one in my travel kit for long x-cntry's.
Bob B
RV-7A Sold
RV-4 Sold
DFW TX
Dues Paid
Old 11-22-2015, 06:29 AM
turbo's Avatar
turbo turbo is offline
I replaced all of my with pieces made out of solid steel. I flattened out the ends of the steel rod and now have a bullet proof system that will never brake.
TURBO YES =VAF= Payed Jan2019
Ed D'Arcy
addicted pickle ball player
Old 11-22-2015, 11:16 AM
posterman posterman is offline
I converted my upright tubing running from the exhaust to the back of the sump to very thick walled 4130 chrome moly - required MAPP gas to heat the ends sufficiently well to pound out flats for the bolts...no breakage in over 450 hours.
Old 11-23-2015, 05:17 AM
Steve Melton's Avatar
what about a washer between the hangar and bracket to give it more room to move?
Steve Melton
Cincinnati, OH
www.rvplasticparts.com
