11-19-2015, 05:59 AM
Originally Posted by singoldsby
Just thought I would put a pic of my cowl on here so everyone is aware of my intake set up. This of course is before any cowl mods. I intend to add vents and duct work if needed.
Yep, those are attractive cowls.
Can you describe, or even better, sketch what you have in mind for cooling mass flow?
Dan Horton
RV-8 SS
Barrett IO-390
11-19-2015, 06:43 AM
The cowl and rad setup is the same as the other two Powersport RV8s used way back when. They never said anything about cooling issues. Huge rad, not so efficient but certainly looks great from the outside and hopefully works as well as the other ones.
11-19-2015, 07:55 AM
I currently fly a 7A with a Renesis, RD1C redrive, with a EC2 controller. I tried your current cooling installation but with enough differences in my installation that I cannot give a positive or negative reply, but I had to change to a different cooling installation due to high oil temps.
I do agree with the other comments about your current fuel pump location. I did suffer a situation with vapor lock and had to redesign my fuel system.
It did take some time to work out the bugs but I thoroughly enjoy the aircraft now and even flew it to Oshkosh this year.
PM me if you would like to know more about my install, I'll help where I can.
http://s1204.photobucket.com/user/sa...y/?view=recent
11-19-2015, 12:09 PM
Clean looking install and airframe. Nice!
11-20-2015, 05:47 AM
Very nice Sam, thanks for the input and i sent you a pm. Looking forward to maybe lining up with you on the flight line at Oshkosh one day...
11-20-2015, 07:08 AM
Ahh, but that's the thing...I have no idea what the other two Powersport RV8's looked like under the cowl. As for "never said anything about cooling", well, that's a little like sex and bank accounts...sometimes folks don't tell all
I'm guessing the Powersports have a cooling flow like the top sketch, and Sam's revised system is like the bottom sketch?
Dan Horton
RV-8 SS
Barrett IO-390
11-20-2015, 07:42 AM
Ross at Simple Digital Systems has RV6 with Turbo Subaru, and have done extensive air flow testing and built under fuselage mounted radiator (similar to P51)..He has constructed very nice fiberglass inlet and outlet ducts ,and as a result I am in process of duplicating his approximate dimensions out of aluminum for cooling my RV 4 with Subaru 2.5 .I am very poor at fiberglass, but may get better as I finish my cowl....Tom
Tomcat RV4
RV4 gone to RV heaven !building Zenith 701
dues paid and worth every penny
Life is uncertain -Eat desert first !
U F O Member since Dec 2017
11-20-2015, 11:22 AM
I saw photos of the Powersport installations before their site vanished. One of the Powersport RV8s flew off at Van's against a Lyco powered one and outperformed it slightly if I recall at the expense of more fuel burned during the flyoffs. I'd love to re-read the RVator article as it's been a while and I don't recall all the details.
True, it was hard to find a lot of info about them outside of the RVator article and Powersport's website. The PS RV8 completed the flyoff so it must have cooled ok at least. With such large rad volumes, inlet area and not many other places for the air to go (assuming minimal clearance air and leaks), it might work similarly to Belted Air's similar setup for their V6 Chevy, both are in the same power class roughly. A bit draggy but effective.
I have read where many Rotary guys have had oiling cooling issues and spent more time solving those than water cooling ones.
Love the looks of these cowlings on RVs.
You Rotary guys have any performance numbers you're willing to share?
11-20-2015, 03:21 PM
Rotary RV
Neat installation! I look forward to seeing more photos in the future! On my 13B installation (RV-9A), I have a large water radiator I'm using, which should have excess BTU's to shed; so I am also installing a water / oil intercooler. Oil cooling has generally been the big issue with rotaries; so I am plumbing the hot oil coming from the engine and running it right into the water/oil intercooler to drop the temps a bit; and then will run it through the stock Mazda air/oil cooler, prior to running it back into the engine. I'm hoping my first flight won't have any oil cooling issues...
Doug
RV-9A / 13B FWF
11-20-2015, 03:41 PM
Sam will have some numbers to share no doubt...
Tracy Crook has a three rotor RV-8, and I think he once said he was seeing something like 3,700 fpm initial climb rate, and he has to watch his power at cruise to avoid exceeding VNE. I don't have access to my home computer where all my rotary data is kept; so maybe Charlie England can provide some of the hard numbers that Tracy has reported over the years with his "4" and "8"...
Doug
RV-9A / 13B FWF
