Old 05-29-2015, 10:48 PM
vgb vgb is offline
Smile cooling
I always had high oil temps and cylinder temps on my RV7A. Changed to a better cooler to help oil temps. Still had high cylinder temps. I installed one antisplat cowl flap and I keep the temps down on climb and level off and shut the cowl flap. It has worked great for me. Its harder to cool things down after a climb. My 2 cents worth
Old 06-03-2015, 07:24 AM
BobCollins(AA)'s Avatar
BobCollins(AA) BobCollins(AA) is offline
Today I am getting two EZ Cowls that I will install on the airplane and I will post the results after my next flight.
Bob Collins
ATP, CFI, CFII/MEI
RV-7A (sold)
Now Flying P337
Old 06-06-2015, 05:24 PM
Cervelott Cervelott is offline
Can't wait to hear how it works out Bob.
How are you going to determine the optimum placement of the flaps?
Old 06-14-2015, 02:05 PM
After installing two anti splat electric cowl flaps I finally manage to reduce the CHT by 30 degrees and the oil temp by 15degrees.
Bob Collins
ATP, CFI, CFII/MEI
RV-7A (sold)
Now Flying P337
Old 06-14-2015, 02:25 PM
AltonD's Avatar
AltonD AltonD is offline
All the reading I have done has the best FW mounted oil cooler installation with 4" scat.
Is your cooler mounted vertical or horizontal? If vertical, the inlet should be at the bottom.
The ramps on the cowling inlet, are the ends sealed up such that they cannot be a bypass source?
Alton DeWeese
N526RV RV7A Tip Up, IO360 180 W/Hartzel BA prop.
Flying ~950 hours since Aug 2010
N4IDH
Construction Log
?The secret of getting ahead is getting started. The secret of getting started is breaking your complex overwhelming tasks into small manageable tasks, and then starting on the first one.?
?Mark Twain
Old 06-14-2015, 04:48 PM
BillL BillL is offline
Great to hear your issue is resolved. With timing advance, and piston jets, this is probably a lower cost way to go as opposed to wrestling with a new cooler installation!
Bill
RV-7
Lord Kelvin:
Old 11-15-2015, 09:26 AM
Selma Selma is offline
Default CHT high - Oil temp low
seems to be different flying either an injected or a carbureted engine, is it?
Since the installation of a G3X Touch panel in our flying RV 9a O320 FP we can see all these phantastic numbers as CHTs a.s.o. We didn't know before that CHTs on this engine are pretty high in climb (450 F) and during high speed cruise (400+). Only the oiltemp remains low (160-180 F) in the cruise as it did before. Louvers or EZ cowl flaps from AntiSplat would lower CHTs what would be appreciated. But this way oil temps probably would be lower as well, what is contrary to what is beeing needed.
Any ideas ?
Pit
flying RV9a
a father & son project
Old 11-16-2015, 09:30 AM
krw5927 krw5927 is offline
Any ideas ?
Add the cowl flaps or improve your baffles to lower CHTs. Then use aluminum tape to cover part of your oil cooler. In summer my oil cooler is 1/3 blocked. In winter I will probably need to block more of it.
Kurt W.
RV9A
FLYING!!!
Old 11-17-2015, 04:19 PM
Smilin' Jack Smilin' Jack is offline
Bob,
I am glad to hear the cowl flaps work well. I thought you would be pleased. Just had a nice trip to Kitty Hawk... and had a blessing on the wind last Friday 55 kts directly on the tail... and behold... on the return Sunday I had no wind. Same day Friday the 13. that Cirrus deployed his chute in North Carolina after an engine failure, what the pilot said. He is from PDK. so I will find out what happen. They had a video of it after it was on the ground and the chute inflated again and flipped it over on its back.... you can Google it.
It sure was nice to see a speed of 258 on the GS.
Jack
Smilin' Jack & Anita Hunt
N507H RV7, KJZP Jasper, GA
EAA690
APRS/ WB4JKY
Retired Corporate Pilot CFI-AI, MEL
CE500, LRJT, HS25, C650, SBJT, CL60
Hunt Aviation, LLC.
Pilot Service, IPC's Biennials.
Comm Glider
Old 11-23-2015, 03:56 AM
Cool flying RV9a
Kurt,
thanks, baffle seals are redone, no leaks, even the washer at the baffle behind cyl.3 was installed which remarkably lowered the #3s CHT. Now #2 is the hottest. Van's oil shutter is a handy device which is easily beeing added and controlled from the panel.
If we are flying 75% on a hot day we will get 400+ CHT on #1,2 & 3. But who would like to fly the cruise whith opened cowl flaps? Thats the problem.
Pit
flying RV9a
