Old 11-12-2015, 09:55 PM
ChiefPilot's Avatar
ChiefPilot ChiefPilot is offline
Default Rolling shutter explained
Came across this image on reddit, thought some here might find it interesting. It's a visual explanation of the rolling shutter effect on the prop on all the RV videos that get posted around here.
Brad Benson, Maplewood MN.
RV-6A N164BL, Flying since Nov 2012!
If you're not making mistakes, you're probably not making anything
Old 11-13-2015, 03:23 AM
RV6airplanePilot's Avatar
RV6airplanePilot RV6airplanePilot is offline
Default True, but fixable
https://www.youtube.com/watch?v=UljfdzjZ2VY
via Gopro with 2 sunglass filters carefully taped on, Gopro mounted to bill of my baseball hat with double tape and alum strip with 2 bends to fit curve of bill (camera removed from orig case). Purchase of optional remote mic highly recommended. Only about $25. Can be put in earcup of headset.
https://www.youtube.com/watch?v=Hv1qEXk7slU
Dale
ATP, dreamer and maintainer; but not a builder
RV6a N18XP 960TT (builder: Jerry Cochran)
RV6a flight experience 2100 hrs
Superior IO-360 2007
Hartzell Blended Airfoil Prop
Dual LS EI, Dual Battery
GRT HX efis & RAIM GPS, 2 axis GRT autopilot
G696, GDL39 WX, Traffic
Dynon D10
Gear Leg Stiffeners from Woodmanrog
Old 11-13-2015, 06:05 AM
ChiefPilot's Avatar
Oh for sure - addressing it is trivial. I just thought this was a nice visual explanation.
Old 11-13-2015, 06:37 AM
n816kc n816kc is offline
Default comprendo?!
great visual depiction.
Kevin Crews
Bartow, FL
RV-6 'Woo hoo!'
2019 =VAF= donor
Old 11-13-2015, 07:24 AM
Default Yes, very good
Yes, it is a good explanation. I also think many don't know how to fix; as you said most videos posted have the "distraction".
Dale
Dynon D10
Old 11-13-2015, 08:11 AM
Rupester Rupester is offline
Excellent! Always wondered why that weird prop effect always showed. Thanks for posting.
Terry Ruprecht
RV-9A Tip-up; IO-320 D2A
S. James cowl/plenum
(Dues paid thru Nov '18)
Old 11-13-2015, 10:49 AM
C. Brenden C. Brenden is offline
Default sunglass filter?
Love the graphic explanation of the rolling shutter. Your filter seems to have been a great fix! What material works best to filter out the prop and where is a good source?
Craig Brenden
RV6 built, flown, and sold
A&P, EAA Tech Counselor
EAA Flight Advisor, CFII
Air Traffic Controller
Old 11-13-2015, 11:44 AM
RVDan RVDan is offline
Here is a practical demonstration of what rolling shutter is about and the cure.
https://youtu.be/4lHlzRw_Oek
Dan Morris
Frederick, MD
PA28-140
Hph 304CZ
RV6 built and sold
N199EC RV6A flying
Learn the facts. "Democracy dies in darkness"
Old 11-13-2015, 12:58 PM
RV7A Flyer's Avatar
Back in the old days of film, focal plane shutters would cause "curved props" unless the lens was stopped down and the shutter speed slowed.
Leaf or diaphragm shutters would not do this, IIRC.
Old 11-13-2015, 02:25 PM
mike newall's Avatar
mike newall mike newall is offline
https://www.youtube.com/watch?v=QmQR...ature=youtu.be
Shows the effect of a neutral density filter on a GoPro.
"I add a little excitement, a little spice to your lives, and all you do is complain!" - Q
Donated in 2020
