Originally Posted by David-aviator
- is the RV-9 OK under the Rules of Competition?
See items "o" and "p" below from the IAC rule book. RV-9 is OK, a C-172 not so much.
2.3 AIRCRAFT AND EQUIPMENT ENTRANCE REQUIREMENTS
(a) Airworthiness Certificate.
(b) Aircraft Registration Certificate or military serial number designation.
(c) Aircraft operating limitations.
(d) Current aircraft weight and balance.
(e) Copies of entries from Aircraft and Engine Log Books, appropriate to the aircraft’s Airworthiness Certificate.
(f) Certificate of Insurance verifying coverage of $1,000,000 property damage and $100,000 single limit bodily injury minimum.
(g) Aircraft must not have obvious physical damage or potential structural problems as would be indicated by wrinkles in metal or fabric coverings or loose structural members.
(h) Complete freedom of movement of the controls is required.
(i) Aircraft must be free of foreign and loose objects.
(j) On cabin-type aircraft, the cabin door release mechanism must be operative and free of corrosion.
(k) Dual seat belts with separate attach points and a shoulder harness are mandatory for Advanced and Unlimited (power and glider) categories. The same equipment is strongly recommended for Primary, Sportsman, and Intermediate power categories, but is not mandatory except when IAC Technical Monitors deem them necessary for the sequence being flown in these categories.
(l) Hazardous conditions in the engine compartment such as cracked exhaust, fuel leaks, or excessive oil leaks which can be observed through cowl openings and service doors will be brought to the pilot’s attention and, if uncorrected, are grounds to deny registration of the aircraft.
(m) Propeller shall not have any apparent physical damage.
(n) The personal parachute or the aircraft’s ballistic recovery system, if so equipped, will be in good general condition and will be current in accordance with FAA regulations.
(o) Aircraft Structural Standards - Experimental (Amateur-built and Exhibition): The IAC cannot and does not purport or attempt to regulate or require aircraft structural standards for participation in the sport of aerobatics. Each competitor is solely responsible for insuring that his or her aircraft is structurally and mechanically safe and capable of performing whatever maneuver the competitor intends to fly. The Technical Committee shall promote conformity to FAA standards of construction and maintenance.
(p) Aircraft other than Experimental (Acrobatic): Structural standards for other than experimental aircraft are the responsibility of the controlling government agency. These aircraft must comply with the IAC entrance requirements. Aircraft will not be permitted to fly any maneuvers restricted by the licensing agency.
(q) A radio capable of transmitting and receiving common VHF frequencies.
(r) The use of a helmet is strongly recommended for all competitors and safety pilots, but is not mandatory.
