Old 11-11-2015, 03:12 PM
Mohammed Mohammed is offline
Default Dimpling hard to reach HS skin holes
Hi
What is the best way to dimple the 6 holes at the HS leading edge in the middle apart from using the pop rivet dies?
Mohammed
RV-8 Super Slow Build
First RV project in Saudi Arabia
Old 11-11-2015, 03:33 PM
Mel's Avatar
Mel Mel is offline
Why do you not want to use the pop rivet dimpler?
I've built at least 7 airplanes using nothing BUT the pop rivet dimpler. It works great, provides a beautiful dimple and you will NEVER punch an extra hole with it.
RV-6 Flying since 1993 (sold)
<rvmel(at)icloud.com>
Old 11-11-2015, 03:49 PM
YellowJacket RV9 YellowJacket RV9 is offline
^Now that just sounds sadistic.
But I'd get and use the pop rivet tool. You will use it much more during the build. There is nothing worse than screwing something up because you didn't want to buy the proper tool, and then finding out down the line that you needed the tool eventually, anyways.
Chris
Chris Johnson
Old 11-11-2015, 04:02 PM
wirejock's Avatar
wirejock wirejock is offline
Default HS holes
Draft a helper to flex the skin far enough to dimple. It can be done. Just take your time.
Larry Larson
Estes Park, CO
wirejock at yahoo dot com
Disclaimer
Old 11-11-2015, 04:34 PM
I've used these in tight spaces many times:
http://www.averytools.com/prodinfo.asp?number=550
Kyle Boatright
Marietta, GA
2001 RV-6 N46KB
2019(?) RV-10
Old 11-11-2015, 04:46 PM
Mel's Avatar
Mel Mel is offline
I don't think that will work on the HS leading edge holes.
Old 11-11-2015, 04:57 PM
You're right... I was thinking of dimpling the small spaces like at the TE of the old folded ailerons and flaps.
The pop rivet tool is fine in this application. As is a rivet gun, a male die, and a bucking bar with a pilot hole and countersunk relief machined into it.
Kyle Boatright
Marietta, GA
2001 RV-6 N46KB
2019(?) RV-10
Old 11-11-2015, 08:36 PM
spark68 spark68 is offline
Default Pop rivet dimpler
On a related note, I've had trouble finding the right size "nail" to pull the pop rivet dimpler with. Any tip on which nail works best? Mine seem to pull the head through quickly without fully forming the dimple. Seems like the nail is too small, but couldn't find a larger size that would fit in the dies...
Mark Curley
RV-6 (under construction)
dues paid 2020
Old 11-12-2015, 08:33 AM
izzybear's Avatar
izzybear izzybear is offline
Default Hello Saudi Arabia!
Mohammed,
I have just redone this part of the build because I didn?t like how some of the holes came out on the HS service bulletin. If you are have the DRDT-2 dimpler, then it works great, set up on the edge of a work table. The HS skin slides in the top throat of the DRDT-2 for dimpling and the bottom part of the skin sits under the work table surface out of the way. There is enough angle in the DRDT-2 base that the bend of the HS skin fits right in there. Good luck!
Jim
RV-8 N223GT (reserved)
Finish - arrived 10/7/15
Fuselage - arrived 3/14/14
Wings - arrived 3/7/13
Builder # 83331
www.mykitlog.com/izzybear
VAF Dues gladly paid up till December 2020
"The ultimate responsibility of the pilot is to fulfill the dreams of the countless millions of earthbound ancestors who could only stare skyward and wish." - Unknown
