Old 10-28-2015, 01:07 PM
DAS DAS is offline
Default whirlwind 74RV in taildragger?
was talking to the guys at whirlwind, and they have new prob called 74RV, which is 74inches, would this be a problem on a taildragger?
my interp of the info on vans site is that the 72 inch is rec for this application.
thought from the group?
das
Old 10-28-2015, 01:19 PM
flyinga flyinga is offline
What model plane? On my RV8 I have 72" and can't imagine one more inch making much difference as there is plenty of ground clearance.
Jim Averett
RV-8
TS36 - Silver Wings
Fredericksburg, TX
Old 10-28-2015, 01:20 PM
miyu1975's Avatar
miyu1975 miyu1975 is offline
I fly a 74 inch hartzell on my TW rv7, no problems with ground clearance.
Ryan Allen, CFII
RV7 N612RA, flying since july 2012
E-170/175
RV10 Tail Kit complete, Wings 90%, fuse on order
Acro Sport 2, building
Old 10-28-2015, 03:22 PM
DAS DAS is offline
thanks, I'm a RV7 tailwheel
das
Old 10-28-2015, 03:26 PM
Larco's Avatar
Larco Larco is offline
74 inch Hartzell RV 7 works for me over 1000 hrs
Larry
Old 10-28-2015, 05:43 PM
gblanck gblanck is offline
No problem at all with the 74RV in an RV-8 taildragger. I originally had the 200RV 72" blades and swapped to the 74RV, no complaints.
Greg Blanck
RV-8 Completed March 2014
Redwood City, CA
RV-8 Build Log
Old 10-28-2015, 05:57 PM
greghughespdx's Avatar
For people flying the 74RV, curious what engine and HP you're running with?
Building RV-8A since Sept 2014 (N88VX reserved)
Aurora, OR (EAA Chapter 105)
Old 10-28-2015, 07:08 PM
ronschreck's Avatar
ronschreck ronschreck is offline
Default Not to worry...
Mine is a 78-inch Hartzell composite constant speed. Still plenty of clearance.
Ron Schreck
IAC National Judge
RV-8, "Miss Izzy", 2250 Hours - Sold
VAF 2021 Donor
Old 10-29-2015, 11:24 PM
OGee OGee is offline
Default Whirlwind 72" vs the 74"rv
das
Any performance comparisons between these two props - actual or hearsay?
OldGuy
N58TX RV-8 QB
Avionivs
Prior, 1955 C-170B.
Old 10-30-2015, 01:00 AM
I've had both the 200RV and 74RV on my IO-375 powered RV-8. I haven't done any credible performance comparisons, but gut feel is that performance is generally similar, 74RV seems to accelerate, climb and slow down better, 200RV might have a slight edge in cruise speed.
The 74RV looks faster on the ground and gets a lot more attention than the 200RV did.
Greg Blanck
Redwood City, CA
RV-8 Build Log
