Old 10-28-2015, 10:12 AM
Sylvainsting's Avatar
Sylvainsting Sylvainsting is offline
Default Ray allen stick grip and VPX
Hello,
Working on m'y stick grip wiring, I saw a wire to connect to 12 v (+). Is it mandatory to connect it when we use a VPX ? I think we don't need it for the trim, but perhaps for the radio PTT switch or the two others ? I have to connect the AUto pilot control steering and also my smoke system.
I am a little confused and need some help.
In advance thank you
Sylvain
RV7 QB (F-PSED), Tip Up, Aerosport IO-375, James Cowl, WW 200RV, Dynon Skyview, VP-X sport, Day VFR,
Flying...
Phase 2
Old 10-28-2015, 10:41 AM
bruceh's Avatar
bruceh bruceh is offline
All of the switches on the stick grip should simply connect to ground. The VP-X is looking for the switch lines to be pulled down to ground. Same for PTT.
Bruce Hill
2020 VAF donator
