Old 02-04-2015, 05:52 PM
crabandy crabandy is offline
I didn't install one either, saved weight/$$/complexity. I never used them in the factory airplanes and they usually didn't work all that great.
Then I pulled in front of my hangar on a typical windy Kansas day, the airplane wouldn't stay put unless I had my feet on the brakes. I eventually let the airplane weathervane into the wind (pointing downhill) and roll off the ramp and into the soft mud/grass.
I'm still not going to install a parking break in this plane, if I still have the same hangar my next one will probably have a parking brake.
RV 7 400 hours and counting
19 donation done
Old 02-04-2015, 11:17 PM
bruceh's Avatar
bruceh bruceh is offline
Default Definitely a "nice to have" option
I've used mine more than a couple of times on various ramps to give me time to get out and chock the wheels on unlevel surfaces.
Here are a couple of photos of my installation.
My only issue is really how close the parking brake handle comes to the side skin. It can be akward to reach down with your left hand and get your fingers around the handle to push the release button.
A microswitch tells the EFIS whether the parking brake is set or not.
Bruce Hill
2020 VAF donator
Old 02-04-2015, 11:31 PM
Bevan Bevan is offline
Originally Posted by scsmith View Post
This statement is not quite true. The valve has a check-valve type function, so you can have the valve closed and add pressure by pressing on the brake more. It won't let pressure out until you open the valve, but you can add pressure with the valve closed.
OK, not sure if mine has that feature. I don't recall seeing that written in the description, nor do I recall seeing the ports labeled for orientation as they would have to be if there was a check valve inside. Is the check valve standard on all parking brake valves? Mine is an older type (Matco I think)with the inlet/outlets arranged 90 degrees from each other. Cannot find an old drawing on the web. Anyone point one out to me?
Bevan
RV7A Flying since 2015
O-360-A1F6 (parallel valve) 180HP
Dual P-mags
Precision F.I. with AP purge valve
Vinyl Wrapped Exterior
Grand Rapids EFIS
Located in western Canada
Old 02-04-2015, 11:49 PM
scsmith scsmith is offline
Hi Bevan,
Mine is also the old Matco with the inlets and outlets 90 degrees from each other. There is a label on the valve body that indicates the flow direction.
In the manual, it actually describes operating it by closing the brake valve first, then stepping firmly on the pedals to pressurize the circuit. Try it.
Here is the URL for the installation drawing for it:http://static.veracart.com/matco/ite.../document1.pdf
Note the arrow showing "flow to brake" and the arrow showing "from M/C" (master cylinder).
To the OP:
I have to say, I wasn't sure I would use mine, but installed it on recommendation from a friend. I'm glad I did. I've probably used it 5 times in 5 years, but when I do, I'm really pleased I have it.
Steve Smith
Aeronautical Engineer
RV-8 N825RV
IO-360 A1A
WW 200RV
"The Magic Carpet"
Hobbs 625
LS6-15/18W sailplane SOLD
bought my old LS6-A back!!
VAF donation Jan 2020
Old 02-05-2015, 04:38 AM
ronschreck's Avatar
ronschreck ronschreck is offline
Default I have a Matco brake...
In over 1900 hours I have never used it!
Ron Schreck
IAC National Judge
RV-8, "Miss Izzy", 2250 Hours - Sold
VAF 2021 Donor
Old 02-05-2015, 11:36 AM
longranger's Avatar
Originally Posted by schristo@mac.com View Post
I have yet to come across a situation that I wish for a parking brake...
You haven't been to L05 solo yet...
RV-7 TU 904KM (reserved)
Construction Log
Old 10-25-2015, 11:28 AM
JanRV6UK's Avatar
JanRV6UK JanRV6UK is offline
Bruce,
When you secured the valve to the firewall - did you also use a doubler plate on the forward side of the firewall ? Looks to me as if the bracket is secured with -3 rivets ?
Jan
Slooow RV6, no hole, builder in UK
Paid up for 2015 ...
Old 10-25-2015, 11:36 AM
bruceh's Avatar
No doubler on the firewall. I don't think it needs the extra strength. The parking brake valve isn't heavy, and it is right next to one of the firewall angles which helps support the stainless steel firewall material.
Bruce Hill
2020 VAF donator
Old 10-26-2015, 01:38 PM
If you've ever experienced that horrible feeling in the pit of your stomach as you turn around to see your unattended airplane rolling toward the fuel pumps, you'll know why some folks opt to install a parking brake. They really do come in handy for those times when you need to temporarily secure the airplane from rolling away from you.
And then there was that time when I had parked a 172 on a ramp dotted with patches of black ice... I hopped out of the airplane, unlocked the baggage door and, in reaching into the baggage area to retrieve the chocks, slipped on the ice and went down in a heap. I sat up just in time to have the horizontal stabilizer whack me on the back of the head as the airplane started rolling away from me, pushed by an arctic blast of wind. Yeah, not one of my better days in aviation. A functional parking brake would have been handy in that situation!
Old 10-26-2015, 02:19 PM
JanRV6UK's Avatar
Thanks !
and would I be correct in saying that you used countersunk -3 rivets to secure the braket to the firewall ? Looks that way from the shop head ...
Jan
