Old 10-23-2015, 08:50 PM
goatflieg's Avatar
goatflieg goatflieg is offline
Default Validation requested for "One Tab Club"
I can't be 100% certain until it's mounted on the completed left elevator... but I believe I may have just joined the One Tab Club.
For details you can go to my kitlog site http://www.mykitlog.com/goatflieg/ but here's a synopsis. I faced the point where I had to decide whether to bend the end tabs on the left elevator skin and trim tab skin or go the riblet route. Much research revealed that this subject is about as infamous as the Primer Wars... but I decided to see if I could build it the way Van's builds it. So I built lots of different forming blocks and jigs, and copied the tabs onto some spare sheet so I could practice on a couple pieces first. Then I followed some advice found here and did my trim tab first, since it's much cheaper and easier to replace than a left elevator skin with stiffeners already in place. I took my time, rejigged as needed, used a lot of care... and I'm really happy with the result. As I see it, the only risk I'm facing is lining up the trailing edges with one side of the hinges already installed per blueprint specs. I'll know when I complete the left elevator and can begin fitting the trim tab... but I've a feeling this is going to work out just fine. I also made sure I primed the face of the inner tabs, so that I had primer between sandwiched parts. I think it looks good... what do you think? Did I pass?
(BTW those wavy white areas along the top edge of the part in this photo are scuff marks from the scotchbrite wheel I used to dress the edge... they really caught the camera flash, and look like dents or deformations, but they're not)
Martin J Filiatrault
Clarkston, MI
RV-8 #83507 - currently working on finishing & firewall forward.
N657AR reserved
Builder websites:
http://goatflieg.blogspot.com/
YouTube Channel:
https://www.youtube.com/user/goatflieg
Dues paid for 2020... extra payment included for psychological therapeutic services rendered.
_______________________
Have you ever gotten the feeling you were smarter than you could ever prove?
Old 10-24-2015, 06:01 AM
blueflyer's Avatar
blueflyer blueflyer is offline
looks good to me. I made 3 of them.
Old 10-24-2015, 08:13 AM
aerhed aerhed is offline
As good as I've seen. Better than a couple of mine.
Actual repeat offender.
Old 10-24-2015, 08:31 AM
BruceEicher's Avatar
BruceEicher BruceEicher is offline
I would still recommend you build a second, just to prove it was not a fluke.
Bruce, Katie, Hana and RV-8 HulaGirl
Old 10-24-2015, 09:20 AM
Snowflake's Avatar
Snowflake Snowflake is online now
Bet you can't do it that nicely a second time...
Rob Prior
Old 10-24-2015, 11:06 AM
goatflieg's Avatar
Challenge accepted. Just finished the tabs on the elevator skin. It was more awkward; the additional sheet metal made it harder to position the tab area where I wanted it, but I made it work. Again. It probably helps that I work really slowly...
Clarkston, MI
N657AR reserved
Builder websites:
YouTube Channel:
Old 10-24-2015, 02:53 PM
Beer30?'s Avatar
Beer30? Beer30? is offline
Default My first one was perfect too...
Of course, my first one was flawless also, but I bought a second one just so Van could have some beer money. Pretty selfish of you to make the man go thirsty.
DD
David Dalton
Longmont, CO
RV-7 Complete,
Flies like a dream!
Lifetime VAF Member
Old 10-24-2015, 06:48 PM
I too am a member of the One Tab Club, but **sigh** I'm also the president of the Botched Chromoly Aileron Pushrod Society.
Doug
RV-9A "slider"
Tail number N427DK
Donation made for 2020
Old 10-24-2015, 08:11 PM
Smilin' Jack Smilin' Jack is offline
Martin,
You can be proud of your work....
I can not say mine has your touch of a master metal worker... but you did a beautiful job.
I guess the rest of the plane will be likewise beautiful.... keep on pounding...
You'll make us all proud.
Smilin' Jack
Smilin' Jack & Anita Hunt
N507H RV7, KJZP Jasper, GA
EAA690
APRS/ WB4JKY
Retired Corporate Pilot CFI-AI, MEL
CE500, LRJT, HS25, C650, SBJT, CL60
Hunt Aviation, LLC.
Pilot Service, IPC's Biennials.
Comm Glider
Old 10-24-2015, 09:11 PM
goatflieg's Avatar
Thanks all for the encouragement. I'm sure I'll have many more botched moments to add to my existing pile, and I'll learn from them all. After all, that's why we're legally allowed to do this... for the purpose of education. But my reason for posting all this is because it's a comfort to hear from others that some of my work is decent. We all need to hear that sometimes.
Clarkston, MI
N657AR reserved
Builder websites:
YouTube Channel:
