Old 10-06-2015, 04:09 PM
ppilotmike's Avatar
Default How much 3M Fire Barrier 2000?
For those who have gone before:
I'm planning to build my firewall similar to what Dan Horton did (i.e. fiberfrax insulation on the engine side, sandwiched by another very thin sheet of stainless foil/sheet). I need to purchase some tubes of the 3M Fire Barrier 2000+ silicone sealant to seal everything up. Anyone have an idea of how much I will need?
Mike Rettig
VAF Dues Current
Old 10-06-2015, 04:21 PM
DanH's Avatar
DanH DanH is offline
One tube should do it.
Dan Horton
RV-8 SS
Barrett IO-390
Old 10-07-2015, 05:26 AM
bruceflys bruceflys is offline
Aircraft Spruce sells a ceramic blanket with the stainless layer already attached. http://www.aircraftspruce.com/catalo...clickkey=62571
Bruce
Panther - Building 2019
RV-12 - Flying 2016; Sold 2018
RV-10 - Sold 2018; Flying 2018
SeaRey - Flying 2012; Sold 2017
Old 10-07-2015, 08:09 AM
T.O.Craig T.O.Craig is offline
Default FIREWALL INSULATION
WHAT ARE THE OTHERS USING ON THE INSIDE OF THE FIREWALL THESE DAYS AND HOW IS IT ATTACHED?
Craig Rufi
FLYING NOW AFTER 13+ YEARS. NICE FLYING AIRCRAFT!!
RV-10/Empennage/Wings/QB Fuselage/Wiring/Doors done finally, Cowling done. Stein panel complete, and connecting all those wires :-))Thousand Oaks, Ca. Dues paid for 2019
Old 10-07-2015, 09:42 AM
ERushing's Avatar
ERushing ERushing is offline
Regarding inside of the firewall - Search DANH's posts. My plan for the inside of the firewall is nothing. Insulation will go on the engine side of the firewall. DANH's research and posts have me convinced. Why risk it for marginal benefit.
Eric Rushing
RV-10
90% done, 90% to go.
Looks like an airplane!
Molalla, OR
Old 10-07-2015, 01:15 PM
ppilotmike's Avatar
Bruce,
I believe my sandwich of materials (i.e. 1/8" thick fiberfrax sandwiched between the SS firewall and another 0.010" sheet of stainless steel) will hold up better against a fire. The material you suggested only has a max temp rating of 1,000 degrees, which might not be enough. It sure would be interesting for Dan H. to do a test on his fire rig of this material though..
Mike Rettig
VAF Dues Current
ppilotmike's Avatar
Thanks Dan.
Mike Rettig
VAF Dues Current
Old 10-08-2015, 09:15 AM
ppilotmike's Avatar
Default One more question..
When riveting together the firewall, should all the rivets, angles and brackets and such be "wet set" using a fire barrier sealant?
Seems like there could be leaks (i.e. carbon monoxide leaks) from an area under pressure (engine compartment) and the cabin if not sealed up. However, Vans doesn't mention sealant in the instructions, at least not during the building of the firewall itself...
Confused.
Mike Rettig
VAF Dues Current
Old 10-08-2015, 10:00 AM
mikeyj350's Avatar
mikeyj350 mikeyj350 is offline
I wondered about this too... What I'm going to do is run some 1/2" wide 3M #433 aluminum tape (-60 - 600F temp range) over all the flush rivets on the engine side of the firewall before laying the fiberfrax and SS sheet. That should provide an airtight seal for 99% of the firewall, leaving only the nutplates and passthroughs as potential leak spots that can be sealed in other ways, like with firebarrier. The 600F temp limit means it should never come close to failing until there' a pretty serious fire that has already penetrated the first couple lines of defense... and the rivets themselves that are covered up by it won't be far behind in failing at temperatures above that.
As for sealing *everything*... I'm not sure if it's practical or even possible to make the firewall be "100%" airtight and burnproof, although of course that is the ideal goal. I think what we're doing (as Dan's testing seems to support) you could probably call 95-99% and that's about as good as we're gonna get. I think it's more robust than the majority of other light aircraft out there, that's for sure... including certified.
Now I'm sitting here scratching my head, thinking why did I not mask off the inside of the firewall when I did interior paint... I'm trying to decide how big a deal it is to have paint on it and if it's worth going to the effort of stripping it off now. Aargh.
Mike Jimenez & Sarah Hammonds
EAA Chapter 33 Prez & Soc Chair
Marion, IA USA
RV-10 In progress! (N165MJ reserved)
-Emp & Wings complete
-Panel wired up, working on Fuse & Finish
-Blog horribly outdated (sorry)
-Too many distractions, we will finish the plane someday!!!
http://mikeandsarahrv10.blogspot.com/
http://www.eaa33.org/
Old 10-08-2015, 11:02 AM
ppilotmike's Avatar
Thanks for the reply Mike. The tape is a good idea, and much easier than trying to fay seal everything with fire barrier sealant. Where did you buy it?
As far as your painting goes, I would think you could use a solvent to remove the paint that's there, but yes, it will be a pain. Give yourself some motivation by buying a nice bottle of something to have once it's all done; the cost of which will be your cost of education.
Mike Rettig
VAF Dues Current
