  #31
Old 10-05-2015, 02:46 PM
Toobuilder's Avatar
The tape at the hinge line is a simple trick to try before you look for a more permanent fix. I did it on the RV some time ago and was not able to duplicate any positive result, but clearly some have.
Michael Robinson
______________
Harmon Rocket II -SDS EFI
RV-8 - SDS CPI
1940 Taylorcraft BL-65
1984 L39C
Old 10-05-2015, 07:19 PM
Mike H Mike H is offline
Originally Posted by erikpmort View Post
I'm so glad it's getting cold.
Another year of high chts over. I'm to the point I don't even fly when it's over 80
I did louvers, cut exit, worked on baffles, it helped. But I still can't climb worth beans until oat goes around 70 or lower. 430 can be hit very easily at 125 climb speed with 19" and 2400 rpm. Yeah sucks so I pretty much nurse it up to altitude until it cools off
Anyway end rant. I almost drilled jet and read things that scared me out of it. Otherwise I love my plane. I would pay good money to take it to someone to fix it.
What is you're EGT spread between full rich and peak at say 60-65% power?
Mike Hammond
A&P IA PPL ASEL
RV-14A kit S/N 140170
Old 10-05-2015, 09:21 PM
erikpmort's Avatar
erikpmort erikpmort is offline
I did this above 8k full rich wot to lean and I'm trying to remember what the spread was. Say it was 200 what would you tell me to do ? I think I recall from my last experiment I was told to drill to more rich.
Erik Mortenson
Rans S-20 low and slow
14 build working on wings
Old 10-06-2015, 04:03 AM
You will need good data first. But if it is a too lean condition I would call Marvel Schebler and tell them what -10 number carb you have and see what carb setting they recommend. I recently "fixed" a 300 hour -9A that was built with a factory new lycoming and ran way too hot in all phases of flight. A new carb and some baffle work did the trick.
Mike Hammond
A&P IA PPL ASEL
