Old 10-05-2015, 09:05 PM
garyr78 garyr78 is offline
Default RV-12 spar question
Are the RV-12 wing spars anodize like the other RV model?
Gary R.
RV-12iS Empennage complete, wing kit on order
Old 10-05-2015, 10:09 PM
XOverZero's Avatar
XOverZero XOverZero is offline
Yes, they are anodized. They used the clear flavor instead of the usual gold. All same same to the metal.
John Halcrow
Tustin, CA
RV-12 120682
Emp/TC done; Wings done; Fuse kit done
"History teaches us that men and nations behave wisely once they have exhausted all other alternatives." --Abba Eban
Paid up until Aug 2021
Old 10-05-2015, 10:48 PM
Thank you John. I asked because I saw a video of a couple guys preping and priming the wing spars which didn't make sense.
Gary R.
Old 10-06-2015, 12:26 PM
Brendan03801 Brendan03801 is offline
I wondered about that myself! My brother and I were like, "these wing spars are too beautiful for us to mess up with one of our ugly (but effective) priming jobs." However, it does appear that all the #30 holes will have to be drilled to make them fit a rivet.
Builder #120893
Empennage completed
Wing kit underway
N603NH reserved
Donated for 2016
http://www.mykitlog.com/Brendan03801
Old 10-09-2015, 04:36 PM
Jackkclark Jackkclark is offline
Default Rivet holes
Interesting...I did not have to drill any rivet holes to get the rivets to go in.
Old 10-09-2015, 05:32 PM
alexe alexe is offline
My score was 50/50. All the #30 holes in one of the spars were undersize, probably because a worn punch was used during manufacture. The other spar was fine. Not a big deal. A reamer makes quick work of them.
Alex
Alex Erdelyi
RV-9A Purchased
RV-12 Built and Sold
Paid through December, 2020
Old 10-12-2015, 03:06 PM
Chopkins Chopkins is offline
What worried me was the state of the edges of the laminates that make up the spar ends that are factory riveted together. Mine all looked like they needed a good fettling and deburring. I obviously left them and tried to ignore the voices in my head talking of stress raisers etc. Are they all like this?
Old 10-12-2015, 03:26 PM
DHeal DHeal is offline
The outer edges of my factory-furnished RV-12 spars (circa 2012 issue) looked very rough and unfinished as well. When I asked Van's about this they told me that this was now the standard factory edge finish and was fine as shipped. The first years of RV-12 spars had nice smooth edges from the factory. Apparently the factory decided that it was cheaper to provide unfinished edges and they determined that this was satisfactory from an airworthiness perspective.
David Heal - Windsor, CA (near Santa Rosa)
EAA #23982 (circa 1965) - EAA Technical Counselor and Flight Advisor; CFI - A&I
RV-12 E-LSA #120496 (SV w/ AP and ADS-B 2020) - N124DH flying since March 2014 - 940+ hours (as of September 2020)!
VAF donation through June 2021.
Old 10-12-2015, 03:31 PM
n538pg n538pg is offline
Wink spar
Hi. all I'am skinning my wings and need to drill the spar hole's to fit the rivet's. Is it ok to do so. The plans say no. Any help will be great. Thank you n538pg
Old 10-12-2015, 04:06 PM
Hi
I didn't drill any holes in the spars. All of the angles attached fine with clecos. Some occasionally needed running through with a No.30 drill just to take a gnats whisker off (one or two thousands of an inch) to allow the rivets to pop in. If you are having to do more than that, something is wrong.
If I had a pound for the amount of times I have thought Vans have got their plans wrong only to realise that its me that's wrong.......
Anthony
