Go Back   VAF Forums > Avionics / Interiors / Fiberglass > Glass Cockpit
Old 10-02-2015, 05:14 PM
glenn654 glenn654 is offline
Default GRT Mini-X
Would anyone know if it is possible to take GPS guidance from the Mini-X?
Glenn Wilkinson
_____________________________________________
RV-4 Sold
N654RV @ MLJ
RV-7 Coming Soon
N987RV Reserved
2015 Donation Gladly Paid
"Maintain Thy Airspeed, Lest the Earth Arise and Smite Thee"
Old 10-02-2015, 05:29 PM
Glenn - that's a question that can be interpreted a few different ways, but I'll take a stab at it.
The Mini, with its built-in GPS, is capable of sending GPS data to other devices via one of the Mini's RS232 serial outputs. One of the more common formats, NMEA 0183, is supported. This is the format that's accepted by many other devices like autopilots.
Old 10-02-2015, 07:55 PM
Len Len is offline
Default Mini X
I have my Mini X as a backup for my HXr and it is connected to my GRT Autopilot. I use the gps from the Mini X driving the AP often. Works great !!
Len Leggette
Greensboro, NC
Old 10-02-2015, 10:26 PM
donaziza's Avatar
donaziza donaziza is offline
Len, I wonder if you could elaborate on this. You're saying you "use the GPS from your mini X driving the autopilot {often}". This implies--- to me anyhow, that you have an IFR airplane and that you've got it rigged/wired, so either your HXr OR your mini X can drive your autopilot. Have I got it right? If so, could you briefly explain here how you did that?
Old 10-03-2015, 08:10 AM
deej's Avatar
deej deej is offline
I have a similar setup with a Mini X and HX combination.
There are two ways I interpret your question, one is the gps source used to drive the autopilot for navigation purposes, and the other is the EFIS that is actually driving the autopilot. You can do both, actually.
Mini X and HX are connected together via a serial link, and they share a bunch of data over that link.
In scenario one above, the HX is connected to the autopilot servos via a serial link, so the HX is directly driving the autopilot. The HX can have multiple GPS sources, one of which can be the Mini X over the serial link connected between the Mini X and the HX.
In my setup, I have a toggle switch on the serial link going to the autopilot servos. A Mini X serial port is connected to one side of the toggle, an HX serial is connected to the other side of the toggle, and the autopilot serial link is the common connection on the toggle. When the switch is in the down position, the HX drives the autopilot, and when the switch is in the up position the Mini X drives the autopilot
Does this answer your question?
-Dj
Old 10-03-2015, 08:13 AM
Len Len is offline
Default GRT Mini X
I have the same type setup with a toggle switch determining if the HXr or the Mini is running the autopilot!
Len Leggette
Greensboro, NC
Old 10-03-2015, 05:11 PM
donaziza's Avatar
-Dj
Yes, perfectly----Thanks so much
