  #11
Old 09-23-2015, 09:42 PM
DanH's Avatar
DanH DanH is offline
Originally Posted by wirejock View Post
I see Proseal used between the skin and firewall flange. Why?
Some builders like a sealant there. Has nothing to do with fire protection.
Dan Horton
RV-8 SS
Barrett IO-390
Old 09-23-2015, 11:55 PM
If stainless is the best firewall, would there be a reason to use a layer of stainless over the fiberfrax rather than foil? How about natural cork?
I am building a 9A. I have a light battery and a fixed pitch Catto. The front end of my plane is light and I believe I will have to put a crush plate to get the CG where I want. The firewall isnt as far forward as the crush plate, but maybe the weight of a second layer of stainless wouldn't be that much of a penalty.
Any thoughts? I will be re-installing my engine next week and still trying to figure out the best options.
rockwoodrv9a
Williamston MI
O-320 D2A
Awaiting DAR Inspection
Old 09-24-2015, 11:06 AM
Bevan Bevan is offline
The cowl area can be pressurised slightly with reference to the cockpit. Therefore any smells, fumes, or smoke from the engine area may be forced into the cockpit under certain circumstances.
Bevan
RV7A Flying since 2015
O-360-A1F6 (parallel valve) 180HP
Dual P-mags
Precision F.I. with AP purge valve
Vinyl Wrapped Exterior
Grand Rapids EFIS
Located in western Canada
Old 09-24-2015, 12:15 PM
I think Dan recommends stainless foil.
Dave
Old 09-24-2015, 12:51 PM
Right on the foil. Just wondering if it would be easier to clean and maintain if it was a sheet.
rockwoodrv9a
Williamston MI
O-320 D2A
Old 09-24-2015, 01:15 PM
Raymo's Avatar
Raymo Raymo is offline
Weight would be the primary reason to use foil with its primary purpose, based on DanH posts, is to hold the fiberfrax in place so it can do its job insulating. If weight were not a concern, thicker should, in theory, be better.
my .20 (inflation).
Ray
Old 09-24-2015, 01:54 PM
Lucio I-NLCM's Avatar
Lucio I-NLCM Lucio I-NLCM is offline
Default firewall insulation
here how I did last year after read tons of threads , finally I followed the Dan way.
Thanks Dan
Lucio
Milano Italy
Blue-7
Old 09-24-2015, 03:28 PM
Thanks for the picture Lucio. My daughter is in Italy now on vacation!
Thanks Dan
rockwoodrv9a
Williamston MI
O-320 D2A
Old 09-25-2015, 07:30 AM
Rockwood
Good choice Italy for vacation, I hope you daughter plans, after all, one day to visit the expo in Milano.
Lucio
Milano Italy
Blue-7
Old 09-25-2015, 08:26 AM
Ron RV8's Avatar
Ron RV8 Ron RV8 is offline
Another way, 1/8 fiberfrax with .015 stainless (forward of the main firewall). Needed weight forward anyways and wanted something more robust than foil.... Forward stainless sheet is not sealed around the perimeter to allow off gassing of the fiberfrax in case of fire.
Ron Townson
Okanagan Valley BC, Canada
RV-8 Completed Dec 2013
Membership renewed Sept 8, 2019
