09-23-2015, 07:48 PM
Originally Posted by John-G
Thanks for the input guys ?. guess an inexpensive gram scale is on the horizon.
I was just trying to avoid purchasing a gram scale because pre-measured is seemingly easier. Plus, I can just hear it now ? ?Did you hear about that guy with the pony tail down at hangar 45? ? Airport security found him with a gram scale and two large bags of white powder?. Honest officer, it?s only micro balloons and flox.
We used syringes to measure out the correct volume for proseal.
09-23-2015, 09:33 PM
Measure tank sealant by weight
Alex - Obviously measuring by volume worked OK for you.
However, the product application data sheet does say to measure the two components by weight.
John
www.dogaviation.com
RV-12 Wings, Empennage, Fuselage, Finishing, Avionics and Powerplant kits all completed
Now Flying!!
Donation paid until September 2021
09-24-2015, 05:09 AM
John,
I will check on the weekend but if I remember right the tin had an mix ratio by volume as well.
Alex
06-25-2018, 11:04 AM
resurrecting an old thread regarding the 12iS tank..
you will need 3 batches -- two for the tank and one for other things (fairings, etc).
The instructions call for you to familiarize yourself with the build and says you'll need 3 hours of uninterrupted work for the tank. I found that to be true (even with rehearsing the build and working without any delay).
In 2 hours, I was only able to finish the top half of the tank (excluding the main access hatch and the two boomerang doublers on the side of the tank (12iS)).
I had a 6oz tube which was ample. After 2 hours, I probably still had 2oz unused.
If I had a helper who could dip the rivets for me and another that did clecos, I probably could have finished the tank in one session .. and in that case, I'd recommend 1 6oz tube.
For solo work, I'd recommend three of the 2-hour 3.5oz cartridges
06-25-2018, 07:04 PM
Ok, so I'm just starting my wing kit, so rather na?ve regarding fuel tank sealant, which I see I will need to seal the position lights to the wing tips too. Can someone explain why one of the many "single can" fuel tank sealants on the market, like this one
https://www.amazon.com/dp/B00B3HXCZ4...v_ov_lig_dp_it
can't be used vs. two-part mix Proseal? Appreciate the education.
06-25-2018, 10:38 PM
https://www.por15.com/POR-15-Fuel-Tank-Sealer
Did you read the info on it? Might be a very good product, but it's effectively a 'slosh' - applied sealant for old corroded tanks. Sloshing sealants have a really bad rep around RVs. I'm not in the camp that thinks it's all the sealant's fault, but I'm sure I'm in the minority.
06-26-2018, 09:23 AM
Thanks for the guidance. Guess I?ll deal with mixing.
