Go Back   VAF Forums > Avionics / Interiors / Fiberglass > ADS-B
Old 09-20-2015, 08:05 AM
Default ADS-B simplest compliance....??
...this government mandate is coming and need to begin to the process to comply.
Have GRT Sport EFIS and Becker mode S transponder. What do I need to get this aircraft in compliance?
Thanks.
RV-12 Build Helper
RV-7A...Sold #70374
The RV-8...Sold #83261
Old 09-20-2015, 08:15 AM
Bill.Peyton's Avatar
Bill.Peyton Bill.Peyton is offline
Dave,
We can talk about it next week when we go to lunch. Which Becker transponder do you currently have?
Bill
Bill Peyton
RV-10 - 1125 hrs
N37CP
First Flight Oct 2012
Aviation Partners, LLC
Old 09-20-2015, 08:47 AM
Originally Posted by Bill.Peyton View Post
Dave,
Bill
Bill,
Thanks.
This is the unit
https://www.aircraftspruce.com/catal...lickkey=213283
It has Becker blind encoder attached to it.
RV-12 Build Helper
RV-7A...Sold #70374
Old 09-20-2015, 10:14 AM
Walt's Avatar
Walt Walt is offline
The Becker you have is a class 2 unit (low power) which is not approved for ADS-B out (class 1 is required).
Walt Aronow, DFW, TX (52F)
EXP Aircraft Services LLC
Old 09-20-2015, 01:01 PM
jclark jclark is offline
Thanks.
Two paths are available to you. Neither has anything to do specifically with the GRT Sport. (I have three Sx's in my RV6).
UAT - a dedicated box/system that does everything (e.g. NavWorX)
1090ES transponder - Garmin (330ES) or Trig (TT-31 or TT-22).
++PLUS++
Certified position source - e.g. Garmin 430W, Garmin 650, newly released position source GPS from Garmin, or AviDyne (I think).
James
James E. Clark
Columbia, SC
RV6 Flying, RV6A Cowling
APRS
Old 09-20-2015, 02:04 PM
++PLUS++
James
If your Sport is an HX then it will remotely operate a Trig 22 box without the control head.
Only ADSB-out is required, but the -in is relatively inexpensive. Many UAT boxes include "in" (but not all); with the transponder route you need a separate "in" box. Be sure to get one that will display on the GRT.
There are several gps position sources that are less expensive than the full-up navigators (but not cheap).
Old 09-20-2015, 02:34 PM
Xkuzme1's Avatar
Xkuzme1 Xkuzme1 is offline
Maybe not cheap, but easiest...
http://www2.l-3com.com/AviationProducts/
RV-4 - 0-320 (160HP)
www.KCFlight.org
Tinker
ATP/CFI/II/MEI
N617TN
Old 09-20-2015, 03:33 PM
Mel's Avatar
Mel Mel is offline
I think you will also need a "certified" GPS. The one in the Sport is not certified.
RV-6 Flying since 1993 (sold)
<rvmel(at)icloud.com>
Old 09-20-2015, 04:23 PM
Walt's Avatar
I sell the L3 NGT-9000 for $5895 with everything included. When you add up the price for a new transponder, certified GPS source and ADS-B receiver it's really very competitive.
It also has a very nice touch screen display that shows weather and traffic.
Old 09-20-2015, 05:01 PM
ADS-B 101.
Getting an education quick.
Thanks.
What is the compliance date before we are grounded without it?
RV-12 Build Helper
RV-7A...Sold #70374
