  #11
Old 09-17-2015, 04:54 AM
Michael, impressive progress! All the best with the rest of your testing and progress to phase one!
Old 09-17-2015, 06:15 AM
rv6ejguy's Avatar
rv6ejguy rv6ejguy is offline
Originally Posted by maxelrad View Post
I didn't use the factory ECU as it requires a code to operate from the body control computer. Custom tuning with the Microsquirt better matches the aircraft reqirements also. My cowl is complete - will show it in a later post. It appears smewhat ungainly.
Took six months to fabricate from scratch s-glass over a wood and plaster buck.
Yes - the box up front is the PSRU - cog belt driven.
Yes, most 2000 and up OEM ECUs are heavily tied into chassis sensors making them complicated or scary to use on other applications like aircraft where those sensors are simply not there to send signals back. You never know what the ECU response may be- from throwing a code to limp mode to fuel pump shutdown, ignition or fuel cuts. Hence the widespread use of aftermarket controllers where responses are predictable and known.
Kudos to get it all in there and running. That's a big job.
Turbo Subaru EJ22, SDS EFI, Marcotte M-300, IVO, Shorai- RV6A C-GVZX flying from CYBW since 2003- 441.0 hrs. on the Hobbs,
RV10 95% built- Sold 2016
http://sdsefi.com/cpi2.htm
Old 09-17-2015, 10:00 AM
Tomcat RV4 Tomcat RV4 is offline
Tomcat RV 4 in Poughkeepsie, NY is finishing up - 4 with Subaru 2.5 stock eng., with airtrikes geared PSRU, SDS ignition/injection control. Nice thing about smooth auto engine, you can test fire without prop. Modifying RV4 cowl to cover Subaru. Fiberglass is not my thing, but can't be any worse than constructing old style slow build -4...Hope to have to airport spring/summer 2016...Someday photos.. If this works out as planned , would be inexpensive way into air....Have photos, but job, family life leave no time to get them onto VAF . Tom
Tomcat RV4
RV4 gone to RV heaven !building Zenith 701
dues paid and worth every penny
Life is uncertain -Eat desert first !
U F O Member since Dec 2017
Old 09-17-2015, 10:20 AM
rv7boy's Avatar
rv7boy rv7boy is offline
Forum Peruser
Default Bad link?
I'm getting a "404 error" on the link. Anybody able to see the photos?
For OP, I suggest you read this...maybe that will work.
Don Hull
RV-7 Wings
KDCU Pryor Field
Pilots'n Paws Pilot
Old 09-17-2015, 03:17 PM
Pat Falley Pat Falley is offline
Cool stability
With all the extra frontal area it might be a good idea to have a smart aero guy look at stability before you commit to flight.
Pat Falley
RV-4, 582M - bought 9/01 - sold 8/20
RV-6, 524JN - bought 8/20 - happy wife.
SNJ-5C, 665C - ground up restoration, almost done.
Old 09-17-2015, 04:52 PM
Toobuilder's Avatar
Originally Posted by cguarino View Post
A little up elevator would make me feel better.
Yep. Engine start with full down elevator...
My Rocket would be on it's nose in a heartbeat.
Will be interesting to watch the progress however. Always rooting for the alternative engine guys.
Michael Robinson
______________
Harmon Rocket II -SDS EFI
RV-8 - SDS CPI
1940 Taylorcraft BL-65
1984 L39C
Old 09-17-2015, 05:49 PM
sblack sblack is offline
It sounds really smooth and quiet. Is it quiet in person? What kind of powerplant is it? Are there many flying? Hats off to you for taking the challenge.
Scott Black
VAF dues 2020
Instagram @sblack2154
Old 09-17-2015, 05:50 PM
blueflyer's Avatar
blueflyer blueflyer is offline
it was a great video. please do keep us posted!
Old 09-17-2015, 06:53 PM
rv6ejguy's Avatar
2.2L Ecotec. I believe the late Bud Warren was working on a LSJ (supercharged Ecotec) a few years back. Not sure if it flew or not.
Old 09-17-2015, 07:08 PM
logansc's Avatar
logansc logansc is offline
This design isn't my cup of tea either, but why all the snarky comments? What's wrong with experimentation and innovation in an "experimental aircraft" and on an experimental aircraft website? You guys sound like you wear helmets to bed. Sheesh!
Lee...
Lee Logan
Ridgeland, SC (3J1)
F1 Rocket #160 flying
