Old 09-15-2015, 10:27 AM
Scrabo Scrabo is offline
Originally Posted by petehowell View Post
Here you go!
Lunch time cell phone greatness!
Printed case from a clever Reddit guy. 2x $1.43 usb extensions. Velcro strap from the bottom on my desk drawer. Yes - those are Legos as spacers........ The antenna is from the $12 SDR stick chopped to ~3" with 2 cables run into the base and soldered. Will probably incorp a small fan at some point. Antenna might get a bit shorter, but works pretty well. (5 Towers at 1000AGL just north of Minne. and good ES coverage of the big boys upstairs)
Clearly, this design is an acquired taste. Proceed with your giggling - I can handle it! My wife says it needs a sign that says "NOT A BOMB!"
It doesnt have a red flashing light or countdown clock, no bleep bleep sounds so acording to my TV research... Its not a bomb
Old 09-15-2015, 10:45 AM
Leland's Avatar
Leland Leland is offline
Here you go!
Pete, when you see the "big boys upstairs", can you also see the little boys below them, when you are close enough?
Old 09-15-2015, 10:49 AM
Love the lego, you just solved a problem for me
Old 09-15-2015, 11:14 AM
petehowell's Avatar
Default Yes Sir
I am getting good coverage on 978 and 1090. WX data is streaming in, I see the local traffic nearby and airliners up top.
Pete
Amateur Radio - KD0CVN
Doggies Delivered - 25+
St. Paul, MN
Old 09-15-2015, 10:51 PM
petehowell's Avatar
Default More fun!
Some people ask why a J-Pole.....I Ask, Why NOT!
Easy build and it rocked on 978Mhz! Some scrap plexi, copper tape and a little math! It opens up the possibility of a flexible antenna that could be incorporated into the canopy as well ......
More to come.....
Pete
St. Paul, MN
Old 09-16-2015, 12:29 AM
Leland's Avatar
But do you see all the local traffic when the airliners are overhead, or do you only see ADS-B Out equipped local traffic?
Old 09-16-2015, 05:21 AM
Bill Boyd's Avatar
Bill Boyd Bill Boyd is offline
Default Forgot about that...
More to come.....
I said I had only played with end-fed half wave antennas at HF, but I forgot about my homebrew J-poles for 2m and 440 fast-scan TV.
Great idea! Just hate to see it attached to RG-174 or similar with losses of 1dB/inch at 900MHz. Well, maybe not quite that bad. Best to mount the receiver right at the antenna and ditch the feedline if you can.
Like I said, awesome geeky thread. Carry on.
-Stormy
Old 09-16-2015, 06:08 AM
petehowell's Avatar
Default ADS-B Out
Hi Leland,
I see all the traffic if it is in the system b/c I am ADS-B out equipped.
So I am seeing 978 out planes, 1090 out planes, and radar targets that are rebroadcast to me as an out equipped plane.
If I have misunderstood your question, let me know.
Pete
St. Paul, MN
Old 09-16-2015, 06:24 AM
dan carley dan carley is offline
Default stratux
does any one know when they might come out with one for garmin pilot?
thanks
dan carley
Old 09-16-2015, 07:13 AM
petehowell's Avatar
Default bad coax
Yes the coax is a joke - thus the small runs on "The Bee" blahahaha
-Stormy
Pete
St. Paul, MN
