  #31
Old 09-08-2015, 08:27 AM
agirard7a's Avatar
agirard7a agirard7a is offline
Default Bank angle
Originally Posted by pvalovich View Post
One thing missing from this thread regarding the 45 - 60 degree AOB turn (I do 60): you need to be familiar with your planes handling characteristics at 60 degrees AOB while aggressively pulling g's near - not into - a stall. Be able to pull hard and know what it feels like to maintain controllability just above (pick a stall margin you're comfortable with) stall. A 45 - 60 degree AOB turn without pulling won't work.
Ok understood. However, what I was taught is pulling up does not occur until the wings are level or close to it in this case. A decending bank turn does not exert any g factor. In no way would I pull up during the bank in this case. I'm not that good. Your seeing the runway back in view when you begin to level off the wings.
Al Girard, Newport, RI
N339AG
RV-9
Old 09-08-2015, 08:29 AM
jonweisw jonweisw is offline
Originally Posted by sailvi767 View Post
Ok, I was not sure in reading the original post. Do you remember if you were getting a warning from the AOA before the wing drop? If not I would still look into the calibration. Your single best tool to performing a max rate turn at high angle of bank and low airspeed should be the AOA.
G
Yeah - Im using an old Dynon (the first one actually) and the AOA doesn't display as prominently as it should. Once I started using it, it was REALLY accurate in predicting the stall. As soon as the arrow touched the red, the wing (s) would buffet.
Old 09-08-2015, 08:49 AM
paul330 paul330 is offline
Originally Posted by jonweisw View Post
The crash I saw has no official NTSB analysis available yet, but it was clear to me and others that there was a significant engine problem on the climb out, followed by the crash 1/2 mile from the field while the pilot tried to turn back.
That pretty much says it all. I don't know if it's some sort of macho culture thing, but almost no-one in UK advocates or practices turning back. Find a field within 30 of the nose and do your best. Worst case, you flop in at 50kts and run into a hedge - you'll probably walk away.
I know, everyone has a field with mountains and/or trees off the end.........
Paul
Mercy Air, White River FAWV
RV-10 ZU-IIZ - "Zeus"
2019 Donation Made
Old 09-08-2015, 09:16 AM
agirard7a's Avatar
Absolutely the best idea given those circumstances. We don't all have that option
In congested areas of the U.S. Not Macho at all, just another tool in the box.
N339AG
RV-9
Old 09-08-2015, 10:37 AM
FuturPilot's Avatar
FuturPilot FuturPilot is offline
Although the RV line has great performance numbers, we as builder/pilots have to understand that this performance only occurs when the engine is running. When it is not running, it is nothing more than a poor glider. For me, turn back....Not without a couple thousand feet between me and the unforgiving earth!
RV-4 Emp started
RV-7 Emp
USAF MSgt Ret
Dan Lade
Old 09-08-2015, 12:46 PM
pvalovich pvalovich is offline
Default Pitch Rate
Don't want to get into an argument, but the above statement is incorrect in the context of optimum turn rate. Pitch rate with respect to to lift vector does not care what the attitude of the aircraft is. To get the nose around as quickly as possible and maintain control you have to lower the nose while rolling then pull. You can descend in a high angle of bank turn without pulling, but why would you do that? ACM 101.
Old 09-08-2015, 12:53 PM
BobTurner BobTurner is online now
Oh go ahead and get into an arguement; his statement is nonsense. If he wasn't pulling any "g's" the plane wouldn't turn. What is true is that you will pull fewer g's if you let the plane free fall, vertically. This is not a constant rate of descent, but falling like a rock. Lose altitude fast!
Old 09-08-2015, 12:56 PM
agirard7a's Avatar
Default Glide performance
Obviously all aircraft have to rely on glide performance should an engine
quit wether it's flying straight ahead or turning around. A stopped prop will have better glide performance than a windmilling one. Yes a plane with a windmilling prop will not have the same glide performance as an idle engine prop. The bottom line is these RV's climb well and fast. When you reach 500-1,000 AGL your not far from the runway, especially in any kind of head wind. In many cases this will be accomplished before you get to the end of the runway. Once you make the initial turn around in a safe decending bank at a comfortable margin of air speed not to fall out of the sky and leveling off, the rest is up to glide performance depending on how far away you are. The times that I have done this, getting back is not the issue, it's getting down without overshooting.
Personally, this whole turn back issue I know is a heated issue with some saying don't ever try it. To me if done correctly it's a skill that may save my life one day. I'm just very greatful I was taught how to do it safely.
N339AG
RV-9
Old 09-08-2015, 01:03 PM
agirard7a's Avatar
Default Stand corrected
Sorry stand corrected, very low g in a decending turn not a "no g".
The point being sure if your maintaing the 100 mph yes you have to pull up not to fall like a stone. So yes some G's will happen , according to my instructor, 1 g. Not to nit pick here but the point was for safety not to pull up extensively while in the bank but wait until you start to level off.
N339AG
RV-9
Old 09-08-2015, 01:16 PM
rvbuilder2002's Avatar
True statement
But I feel compelled to add to it that "done incorrectly, it will likely kill you"
A stall close to the ground is pretty much an unforgivable mistake.
If you practice the maneuver and you can perform equally well when the pressure is on, then your outcome may be good.
For all others.... a forced landing at minimum possible airspeed, even into very unfriendly terrain will probably result in not much more than a damaged airplane.... A lot better outcome than you will get if you stall.....
Scott McDaniels
Hubbard, Oregon
