Old 09-06-2015, 02:27 PM
ron sterba ron sterba is offline
Question If you could tell a newbie builder, what would it be!
I would tell a new builder to install plate nuts under the baggage floor instead of RIVETS. When plans for the RV9 emerged there was not the vast array of electronics as of today market.
I'm sticking to my word on this one. ,,,,,yes ALL rivets drilled out in bag floors.
Ron in Oregon
Old 09-06-2015, 03:08 PM
grayforge's Avatar
grayforge grayforge is offline
  1. Don't stray too far from the plans. The further you go, the longer it'll take.
  2. Try not to refactor things. IE, redoing things for a better option. If I would have determined the final option on many things, it would have saved a bunch of time. Example: I installed standard brake lines and Grove parts. Then redid everything with steel braided lines/Beringer setup.
  3. Read ahead... Like the entire manual. There are numerous areas I had to undo things that I should have just not done. One example was installing the doubler for the Facet carburated RV fuel pump. I knew I was going injected and didn't realize at the time that the Facet pump was for a carburated engine.
  4. Any structure that has piano hinge riveted to 2 sheets of aluminum should have the piano hinge machine countersunk. (Flap hinges)
Speed Is Life
VAF Donation made: 1/28/2020, My RV-7A Build Log
Old 09-06-2015, 03:10 PM
curtis's Avatar
curtis curtis is offline
1st - Stick to the plans! Every time you change something it never ends there and it will drive changes later for what you have done.
2nd - DO NOT buy your avionics until you know you are getting really close to needing them. Avionics are changing at warp speed and nothing is worse than having a first flight with old avionics if your goal was to have a the newest stuff.
RV-6A Slider
550 hours +
Build it light and cheap
Old 09-06-2015, 03:15 PM
C-FAH Q's Avatar
C-FAH Q C-FAH Q is offline
Buy one, it's cheaper.
Gary Wilcox
St.Thomas, Ontario. CYQS
RV7 Sold
www.Facebook.com/Purplehillair
www.purplehillair.com
C-FAH Q now N281CT
gwilcox3 @ gmail.com
Old 09-06-2015, 04:37 PM
TX7A TX7A is offline
Amen and amen!
Sam Evans
RV7-A O-360 C/S
VAF#812
Old 09-06-2015, 04:39 PM
N941WR's Avatar
N941WR N941WR is offline
If you don't have the proper tool for the task at hand, don't make something work,stop and beg, bower, or buy the correct tool. If you don't, you will bugger up the part you have spent 10 hours working on and then order a replacement part AND the tool.
Bill R.
O-360 w/ dual P-mags
SC86 - Easley, SC
www.repucci.com/bill/baf.html
Old 09-06-2015, 04:51 PM
videobobk's Avatar
videobobk videobobk is offline
Since I work with new builders quite a bit, this is personal, and a great question! First, understand what the plans are trying to tell you. That may mean assembling things several times with clecos, or it might mean asking someone else to figure something out. Second, if it doesn't line up right, chances are you have something assembled wrong. Since we work on RV-12s, and the plans are pretty complete, the answer to almost every question is, "Read the instructions." Perhaps it should be, "Understand the instructions." I am a big believer in trial assembly of whole components, even when it doesn't seem important.
Bob
Bob Kelly, Scipio, Indiana
Tech Counselor
Founder, Eagle's Nest Projects
President, AviationNation, Inc
RV-9A N908BL, Flying
Old 09-06-2015, 07:23 PM
wirejock's Avatar
wirejock wirejock is offline
Default Advise
Prime and go with a nose wheel. There. That should get the flames going.
Actually, you got good advise already.
I would add...
1. Pound on scrap, build the practice kits then drill them all apart and do it again.
Drilling rivets is as important a skill as pounding them.
2. When you get tired. Quit immediately. Mistakes inevitably follow.
Larry Larson
Estes Park, CO
wirejock at yahoo dot com
Disclaimer
Old 09-06-2015, 07:28 PM
Van's philosophy: Make it work. This isn't hard.
Many of us (myself included, without a doubt) waste a LOT of time looking for the perfect tool, the perfect method, etc., when "just doing it" will deliver an indistinguishable result 10x sooner.
Kyle Boatright
Marietta, GA
2001 RV-6 N46KB
2019(?) RV-10
Old 09-06-2015, 07:39 PM
rv8pilotpaul rv8pilotpaul is offline
Buy a GOOD bandsaw
RV-8: Still Flying since 2001
RV-3 Sold: Flying now in England!
Starduster Too: Sold
RV-12: Sold
RV-14: Sold
Carbon Cub: N471CC
