Old 09-04-2015, 02:42 PM
Gizmos Gizmos is offline
Default Switch to disable copilot switches?
Has anyone wired a switch on the panel to allow the disconnection of the copilot's switches on their stick? This would take away the chance of someone disconnecting or changing the trim on a cross country flight . If so, how would you do it without a ton of switches.?
Old 09-04-2015, 03:02 PM
newt's Avatar
newt newt is offline
I'd say, "I don't care where we are, if you touch those switches I'm gonna land, kick you out, and keep going. Got it?"
No extra switches needed at all.
- mark
[ Paid up on 3 Feb 2020 ]
RV-6 VH-SOL
Old 09-04-2015, 03:28 PM
sparkcrafter sparkcrafter is offline
I have one on my (not yet flying) rv-6A. The switch goes between the airplane ground and the ground side of each switch. One 'enable' switch handles all of the switches on the copilot stick.
Old 09-04-2015, 03:31 PM
rolivi's Avatar
rolivi rolivi is offline
Don't fly with anyone who touches your stick without asking first.
(kind of goes for people you sleep with too)
Rob
RV-6A (Purchased)
2020 Dues Paid, of course
Old 09-04-2015, 03:55 PM
Mike S's Avatar
Mike S Mike S is offline
Senior Curmudgeon
Ed did it.
http://www.vansairforce.com/communit...&postcount=331
First photo, far right switch of the large group.
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
Old 09-04-2015, 03:57 PM
Kahuna's Avatar
Kahuna Kahuna is offline
I have this to disable the rear stick of my 8. Mainly for kids. Works.
Kahuna
6A, S8 ,
Gold Hill, NC25
Old 09-04-2015, 04:10 PM
GTWreck GTWreck is offline
On side-by-sides, I think this isn't much of an issue, as you can reach over and smack the offending passenger. For tandems, I think it's a great idea, especially if you have trim on the stick.
Aaron Sims
RV-10 (2015 Bronze Lindy)
RV-6A (sold)
Home Field: Mallards Landing (GA04)
Locust Grove, GA
Old 09-04-2015, 04:18 PM
scrollF4's Avatar
scrollF4 scrollF4 is offline
Moderator, Asst. Line Boy
This is exactly what I did for my copilot side Infinity grip. I brought all the switch negative wires to a common guarded on-off toggle mounted on the pilot side of the fuel valve cover. The toggle's other terminal is connected to a local ground point on the main spar. Closing the switch enables the copilot stick pitch/roll trim, flaps, PTT, radio flip, and autopilot activate/deactivate button.
http://www.mykitlog.com/users/displa...g=205591&row=1
Works like a charm.
Scroll
Catch her on YouTube's "Because I Fly!" channel
Exemption waived.
Proud and grateful 2020 -=VAF=- Contributor
Old 09-04-2015, 06:11 PM
Paul K Paul K is offline
Yes, put a toggle switch just above my fuel selector to disconnect the ground to the switches on the copilot infinity stick. Call it my grandson switch. Will post a photo if I can find one.
Paul K
West Michigan
2020 donation made, exempt but worth every dime!
