03-04-2013, 10:17 AM
Originally Posted by PaulR
If you call Crow instead of using the website, they will be happy to accommodate your request...
Give them a call. I recently ordered a set directly from them and they came without the shoulder pads as ordered. I called and Mrs. Crow answered and said the correct replacements would be in the mail that day (they were) and sorry for the mistake and no need to send the wrong ones back. I love dealing with companies like that!
Larry New
RV-7A - Built, flying 900+ hrs
RV-10 - Built, flying 2.9 hrs
??? - RV-12, Subsonex
48 States in 7 Days!
VAF Paid - Annual Autodraft
09-01-2015, 04:06 PM
Rear Seat Belt Attach
I'll be making the bushings and spreading the attach points to accept the 3/16" thick Crow brackets. Could not find any mention of the F-857D&E offset bars on VAF that the plans for the 8 say to use to attach the rear seat belts. The offset bars look like they were designed to have the seat belt attach clear the arms of the flap actuator.
It looks likes you could get away without using the F-857s and simply bolt the Crow brackets in directly.
What have others done with rear seat attach of Crows in an 8?
Dennis Enns
Kingsville, ON
Bellanca Champ 7ACA since 1986, restored 1990.
RV-8 IO375, Hartzell CS, dual PMags.
2020 Donation In
09-01-2015, 04:44 PM
I used the stock setup just as the plans call them out and put the crow mounting bracket into the F857D/E slot. There might have been some slight bending required to align everything, but I can't remember offhand. They are needed to bring the mount points outside the side cover over the flap arms.
Flap motor & switch by Andy Karmy, on Flickr
Andy Karmy
Covington WA
RV-8 - Flying!
RV-9A - sold
Dec 2019 Paid
09-01-2015, 06:54 PM
Andy,
Your rear lap belt attach is different than mine. Mine is a 2002 vintage (see attached DWG32). Yes - I am slow building. The F-857D&E are separate bars that pivot bolt to the airframe attach F-857A&B . The seat belt brackets then pivot bolt to the F-857D&E.
I was thinking of eliminating the F-857D&E and pivot bolting the Crow seat belt brackets directly to the air frame F-857A&B.
[IMG]  [/IMG]
Dennis Enns
Kingsville, ON
2020 Donation In
09-01-2015, 08:40 PM
Ah I see, much different. I would think you could try it easily enough and see if you can make the belt attachment work out with your covers on the sides. Seems like it might work just fine. If not, you can add the other extension back in like the plans show.
Andy Karmy
Covington WA
RV-8 - Flying!
RV-9A - sold
Dec 2019 Paid
09-02-2015, 07:11 PM
Vans said they haven't tried attaching the seat belt brackets direct without the F-857D&E extensions but saw no reason not to give it a try - so I will. Thanks for the reply Andy.
Dennis Enns
Kingsville, ON
2020 Donation In
09-02-2015, 07:16 PM
Originally Posted by rwarre
I was staying at the Mariott in Denver(week-end rate) and got in the elevator with a guy who was wearing a tee-shirt with the Crow emblem. I told him I had Crow seat belts in my airplane, and he replied, I am Don Crow, the owner. You never know who you are going to meet in an elevator.
Yikes, I thought I had written this, because the same thing happened to me. (Not in Denver). Don must ride a lot of elevators!!
VAF# 835
RV-7A- Instrument Panel/FWF/Engine Mounted
Slow build --- ALL THE WAY
Victim of SB-632-B
2020 Dues Paid
09-04-2015, 08:11 PM
Tried attaching the Crow brackets direct on my 8 but there was to much chance of interference with the flap weldment arms so I made up new & longer F-857D&E offset bars to take the thicker Crow brackets and opened up the aft side panel slots a little - not a big deal. This also keeps the Crow brackets and all of the belt out in the open.
Dennis Enns
Kingsville, ON
2020 Donation In
12-25-2016, 12:16 PM
Merry Christmas to me!!
The wife came through with the one big item on my Christmas list!!
[IMG]  [/IMG]
[IMG]  [/IMG]
Never thought I would say I love my seatbelts, but I do!!
9A in progress
Working on Finish kit!!
Mattituck TMXIO-360 red gold
Dues paid Jan 2020
08-10-2017, 10:24 AM
Pullup vs pull down
Can someone explain the whys of pull up tighteners on the shoulder belts please?
I get that for the lap and sub, towards the latch would be technically a pull up, but for the shoulders, Ive only used pull downs. It escapes me why one would do pull ups on the shoulders.......?
Wouldnt pulling towards the latch for each belt be optimal?
Mani
Busby MustangII (FoldingWing) Pending DAR.
Don't be a hater; I'm a cousin with thin wings!
N251Y (res)
