Go Back   VAF Forums > Model Specific > RV-9/9A
Old 08-31-2015, 09:11 AM
Gizmos Gizmos is offline
Default Ray Allen trim with auto pilot RV-9A
I have the garmin install manual 700+ pages. I still have a question on ray Allen elevator/ wing balance servo installation. Is the ra servos hooked up to the garmin gmc 305? Or is the ra servos just used to trim the plane when you are not using auto pilot( gsa28)? Can you use the ray Allen servo for yaw? If not, where do you in stall the yaw servo? I am using two g3x, gud 73,gmu22, and gmu22.
Also I am thinking about AOA , can I use a gsu25 as backup and for the AOA? I will need to purchase this unit. What do you think about using AOA ?
Old 08-31-2015, 09:20 AM
sbalmos's Avatar
sbalmos sbalmos is offline
I forget the section in the manual, but you wire the trim motors *through* the GSA 28 servos. This allows the G3X system to auto-trim when the A/P is engaged. When the A/P is not engaged, trim control signals are passed straight through the servos.
The yaw damper, I think, is really only used for the RV-10, being a bigger plane. I haven't heard of / seen any other RV using the yaw damper servo.
Scott Balmos - RV-9A N112SB
Cincinnati, OH, KHAO
Old 08-31-2015, 09:56 AM
Default Is this the section
I found page d-4 figure d1.4 shows pin 11,12,13 and 14 to switches and trim motor. These pins are on the gsa28 servo. If so, do you have to wire these pins to a ray Allen relay deck to allow both pilot and copilot to have trim switches on their sticks?
Old 08-31-2015, 11:27 AM
DaleB's Avatar
DaleB DaleB is offline
Yep. That's in there too.
Dale
Omaha, NE
Previous RV-7 project (sold)
Old 08-31-2015, 11:43 AM
Raymo's Avatar
Raymo Raymo is offline
Yes, a relay is still required, per installation instructions. There are a number on the market, including the RA brand. I opted for a single board that will handle both trim servos and flap control from either stick.
There is a way to wire both sticks to control trim without a relay. A search of the forum should bring it up.
Ray
Old 08-31-2015, 11:52 AM
sbalmos's Avatar
What board is that, Ray? I'm finishing up my wiring pinout assignments, and was about to order separate RA relays for the trims and flaps.
Old 08-31-2015, 12:14 PM
Raymo's Avatar
This site has single and three axis relays.
EDIT: In the interest of competition, PH Aviation also provides nice relays.
http://www.phaviation.com/
Ray
Old 08-31-2015, 12:25 PM
sbalmos's Avatar
... and now I'm going to have to go back to my notes, or do the research again, because I'm wiring my trim and flap switches to the VPX, then the VPX trim outputs to the GSA servos, and then the trim motors. I forget whether the relays are needed for VPX trim/flap wiring. Some nagging thought in the back of my head seems to say no.
Old 08-31-2015, 12:39 PM
Raymo's Avatar
No relays required when using the VP-X. If controlling the trim relays from only one stick or switch, no relay is needed. Flaps may need a relay, depending on the load capability of the switch in use. Stick grip switches may not be rated for the load, so a relay could be needed (as in my case).
I am using two Infinity grips and want full control from either seat so went with the 3-way relay from Composite Design. While reviewing the PH Aviation site, I noted they have up-stop limit switches so I just ordered one of those too.
Ray
Old 08-31-2015, 12:47 PM
sbalmos's Avatar
Yup, I'll need relays then. I want full trim and flaps controls for both sticks (Tosten CS-8, using the two side thumb buttons for flaps up and down). Going to be doing my instrument training in my bird eventually, so the pax is my instructor.
