Old 08-27-2015, 12:52 PM
Greenley's Avatar
Greenley Greenley is offline
Default 5/16-24 tap, please help
I am working on the door pins, and the directions call for tapping two inches inside the locking pins with a 5/16-24 tap. My taps will not work, as they have about 7/8" threads then have a larger shank. I ordered Irwin taps on Amazon that showed a smaller shank, but the photo was of something else and when received they also have a large shank. I am still looking for a reasonably priced tap to do this with, I found one online for ~$70 but that seems excessive. Any advice? I called Cleveland and Avery but they do not have anything.
Bill Greenley
My RV-10 is now travel, watch out world!!!!!!
Old 08-27-2015, 01:33 PM
BigD BigD is offline
these guys have a lot of taps to choose from, here's an example with 1 1/2 " of thread:
http://www.mscdirect.com/product/details/55268288
==dave==
Old 08-27-2015, 01:37 PM
bhoppe2 bhoppe2 is offline
The 60 piece tap and die set from Harbor Freight has the smaller shank you are looking for:
http://www.harborfreight.com/60-piec...set-35407.html
Old 08-27-2015, 01:48 PM
Greenley's Avatar
Perfect, thanks. I had not thought about a cheap set would have less steel thus the small shank I need. Going by HF tonight.
Bill Greenley
Old 08-27-2015, 02:23 PM
Waterobert Waterobert is offline
Try mscdirect.com, they should have it
Old 08-27-2015, 02:29 PM
VC62491097 , $22.99 could work. I would call them and ask.
Old 08-27-2015, 07:37 PM
ENCO has 6 inch long 5/16-24 tap with undercut shank for $25-28. Catalog # 326-1526 or 337-4612. Those will be the best option for you. ENCO on line address is use-enco.com
Old 08-28-2015, 06:33 AM
Greenley's Avatar
Thanks for the info, that long tap looks perfect.
Bill Greenley
Old 08-28-2015, 10:06 AM
rleffler's Avatar
rleffler rleffler is offline
This is what I used.
bob
Bob Leffler
N410BL - RV10 Flying
http://mykitlog.com/rleffler
