  #11
Old 08-26-2015, 01:06 PM
Raymo's Avatar
Raymo Raymo is offline
Originally Posted by TS Flightlines View Post
Bill---I dont think you can put a time on it. Some guys are harder on brakes than others. High heat will transfer to the caliper, including the piston and o'ring. So the heat cycles will have an effect on the o'ring, causing issues. How long, is anyone's guess, but I'd have to say 250 hours (?).
maybe Grove, Matco, or Cleveland has a 'recommendation'.
Tom
Probably more appropriate to go by the number of landings versus flying hours. Unfortunately, our aircraft logbooks, unlike military types, don't track landings; it is retained in the pilot logbook.
Ray
Old 08-26-2015, 01:18 PM
N941WR's Avatar
N941WR N941WR is offline
Tom
I have almost 700 hours on mine. Sounds like they should be rebuilt?
I keep my logbook in Excel and since I'm the only one who flies it, I can tell you exactly how many landings I have on it. What I can't tell you is how many of those lands the brakes have been used.
Bill R.
O-360 w/ dual P-mags
SC86 - Easley, SC
www.repucci.com/bill/baf.html
Old 08-26-2015, 01:35 PM
N941WR's Avatar
Default I went to the source
I called Cleveland AKA Parker Hannifin and was told to replace the O-rings in the master cylinders every 10 years. The O-rings in the calipers should be replaced every year, every two years at the most. The reason, I was told, is because of the heat build up in our small brakes can cause the O-rings to fail.
He mentioned that they consider 50 to 100 hours a year normal.
Bill R.
SC86 - Easley, SC
Old 08-26-2015, 02:04 PM
Well, that's certainly illuminating. Guess I have a new item to add to the annual list.
Bob Collins
St. Paul, MN.
RV-12iS Powerplant kit
Old 08-26-2015, 03:17 PM
BillFear BillFear is offline
Default makes good sense
We have a lot riding on those little o-rings. As I recall there is only one of them on each side. Thanks for the excellent post Bill.
Bill Fearheiley
Lake Norman, NC (14A)
RV7a N705RP (no longer own)
Contribution in for 2017, money well spent
Old 08-26-2015, 04:02 PM
grubbat's Avatar
grubbat grubbat is offline
Default Carpet
I know a feller who had an rv6a which had nice dark carpet. It was so dark, that he never noticed the sloooow brake fluid leak until one day, before he took off, brakes felt kinda mushy but nothing to write home about. Upon landing at long runway, right brake was unresponsive so long rollout was in order but no right turns. He got to walk his fine plane to the tiedown area. Carpet was completely saturated with brake fluid. Carpet went to the trash. Brakes needed new o-rings and was returned to service. Pilot was re-educated on pre-flight stuff and he too was returned to service. He said the -A model is no fun without brakes.
Craig
RV-3 Sold
RV-4 Sold
RV-6a Sold
RV-9 IO-360 CS, Built and Flying
Aerostar 600A, Family Hotrod
Old 08-26-2015, 07:20 PM
50-100 hours? HUM---well seems kinda often to me, but if thats what they recommend. YMMV of course. I guess we'll be keeping several set of o'rings handy, as well as our pressure bleeder.
Tom
Ridgeland, SC
Old 08-26-2015, 08:11 PM
flyboy1963's Avatar
Default non-mechanic question.....
just some questions to learn from, no accusing here....
after a brake rebuild, do you have to break the pads in with long taxi's, or hard braking on a couple of landings? I would hope deficiencies would show up there.
what would show up at run-up when holding brakes for only a few seconds at high thrust? could you miss a slow leak?
Pistons/o-rings, just how much degradation can happen in a year or two? obviously more potential in hot/cold, dusty, seawater etc. or commercial use, but the Waddington effect of fully rebuilding my brakes every year after 25-50 landings seems counter intuitive.
what if you are using viton o-rings and synthetic fluid?
Perry Y.
RV-9a - SOLD!....
Lake Country, BC
Old 08-26-2015, 08:18 PM
flightlogic's Avatar
Default Happens
When mine failed, it was just after the engine sputtered on climb out. Later found rain water in the tank. Rode the brakes hard to get stopped before the runway ended. Brakes got very hot... then the puck blew the o-ring. Smoke coming out and a power screw driver is just not fast enough to get a wheel pant off! Found that someone had put one puck in backwards. Very little clearance under hard braking for the o-ring. I wish the puck was like the Claymore back in the day. At least it told which way to face it !
"Kindness is never a bad plan."
exemption option waived. Donation appropriate.
Old 08-26-2015, 08:33 PM
Infidel's Avatar
Infidel Infidel is offline
I'm still baffled with the left brake failure and left wing impact/damage. No flame here either, but having a hard time drafting it in my mind.
