Got a Skyview, steam gauge and now Mini X all hooked up with Nylo-Seal -4 tube and fittings.
That is 1/4" OD tube with .035 wall . Then there is an insert placed in each tube end before locking it down in the union "T", elbow or whatever you are using. (insert part number is 259-N04.)
http://www.aircraftspruce.com/catalo...hanyloseal.php
The hole in this insert is small, just slightly over 1/8".
Is this big enough? What most people are using?
Can you get a seal without using the fitting in the end of the tube?
